2008-2010 [ZSP110]
Why is it harder to shift into REVERSE than any other gear?
Old Oct 31, 2007 | 09:39 AM
ChiSao's Avatar
Default Why is it harder to shift into REVERSE than any other gear?
Is this just something that happens with ALL sticks? It just seems like it takes more work to get the car into reverse. Sometimes grinds a bit or just doesn't "seat". I've driven 2 other sticks, but a while ago, and can't remember if they were like that too. Thank you!
Old Oct 31, 2007 | 01:22 PM
SLODEANIS's Avatar
I haven't had any problems with engaging reverse on my xD. This is what I do: If the vehicle is in neutral, I first put into first gear then place it into reverse. This causes the main shaft in the transmission to stop spinning preventing any reverse grind. As many may know, the xD does not have a syncro on reverse and this is why it grinds if you have it in neutral then immediately press the clutch and put into reverse. Engage another gear first then reverse.
Old Oct 31, 2007 | 01:28 PM
playindagamewell's Avatar
OhioScions
Taken from: https://www.scionlife.com/forums/vie...291&highlight=
Originally Posted by playindagamewell
Originally Posted by MrZero
Originally Posted by XtraDeviant
i'm not amazed about the tranny breakage... I'm more surprised by the fact that u did 3000 miles in 1.5 months..
I am at 5k miles and have only had it 2 months or so....
and I am having a tranny problem as well... mine is stick though... my reverse keeps locking me out, then when it does go in it, grinds in... I brought it to the dealer the other day and the service guy told me all toyotas do that(that the tranny's aren't synchro'd) I am gonna give my dealer 1 more chance to fix this in about a week, if they still refuse I am contacting scion straight and I am going to work on that dealer losing their scion license...
i have the same issue when i try to go to reverse too quick
make sure you have the clutch PUSHED IN all the way when going to reverse
like it or not... the dealers explanation is actually a correct one.
Old Oct 31, 2007 | 03:40 PM
petalfuzz's Avatar
"reverse keeps locking me out, then when it does go in it, grinds in"
My husband's Yaris does this too, I'll have him try shifting into 1st and see if that helps.
Old Nov 1, 2007 | 03:06 AM
offroadinfrontier's Avatar
it's normal. every stick i've ever driven does this. its a pita sometimes on older cars, because they don't want to unstick, but rowing into 1st then R usually fixes it. It's to keep you from throwing your car in R while going forward. Always make sure to be at a complete stop, tho. as already posted, no R syncros (i dont know of any stick that does, really).
Old Nov 1, 2007 | 03:56 AM
jamesIV's Avatar
All manufactueres neglect to put syncrhos in for reverse because they are not needed, you dont use reverse enought to worry about an occasional grind. Shifting to first and then reverse usually fixes the problem. Never shift into reverse after you are moving.
Old Nov 1, 2007 | 03:59 AM
paul34's Avatar
Reverse is a straight-cut, unsynchronized gear.
As such, sometimes the teeth a bit off, and the gears won't slide together.
It happens with any manual car unless it is one of the extremely rare cars with a synchro on reverse. I honestly can't think of a car that does, but I have heard of a few. Ultra luxury.
Anyway, what needs to happen is that you need to turn the gear a bit so the teeth line up.
Either use a synchro in another gear (I use 2nd), or just go to neutral, let the clutch out, then clutch in and go to reverse (double clutch).
If you're grinding with normal pressure then you're either moving (no, rolling slightly while going into reverse is not cool), or don't ahve the clutch all the way in.
Old Nov 2, 2007 | 07:16 AM
pyrocuervo's Avatar
Hey thanks people, I just got mine today!!! and it did this!! thanks for the info...
Old Nov 3, 2007 | 09:45 AM
superboxcarxb's Avatar
put it into first, let the clutch catch, but not enough to kill it, then put it into reverse like butter. This is what i do in the mornings.
Old Nov 4, 2007 | 07:22 PM
OPINIONATOR_xD's Avatar
Yeah. I heard the same thing about first putting it into 1st gear or 5th (not sure which gear) to release tension on the shifting rails and synchros.
Old Nov 8, 2007 | 08:27 PM
91DA9's Avatar
To line up synchros, the way I learned that has been the easiest, and has worked on any car is this:
For 1st Gear - Depress the clutch, go from Neutral into 2nd gear, THEN move up to first.
For Reverse - (VEHICLE MUST NOT BE MOVING) Depress the clutch, put the tranny into 3rd gear, move down to 4th, THEN into Reverse, if it's a 6-speed tranny go 5th to 6th first.
I've never gone wrong using these techniques, and highly recommend always using another gear before shifting into 1st and Reverse, as it will make your tranny last much longer.
Old Nov 9, 2007 | 10:46 PM
91DA9's Avatar
Maybe not, but grinding the ____ out of it every other day would certainly do the trick....
Old Nov 10, 2007 | 01:57 PM
GuiLLo_xD_PR's Avatar
don't reallly know but my xA did the same thing as new so now i am used to it...
evolving_machine
Oct 21, 2023 01:16 PM
Brimhall_29
Jun 20, 2015 03:40 AM
ky_jelly
Jun 12, 2015 04:31 PM
JcBgOe
Mar 16, 2015 12:57 PM
hnefrdo
13
Mar 17, 2004 08:05 PM
