Go Back   Scionlife.com » Scion xB Classic » Scion xB 1st-Gen Owners Lounge » Scion xA/xB 1st-Gen Wheel & Tire
Register Forgot Password?
Wheels and tire combinations...
Click Here
Reply
Old 11-12-2007, 11:35 PM   #1
ronsweden
ronsweden's Avatar
ronsweden 72/M
Default Spacers on a set of 18x7s
Re: Offset and spacer questions.
I am running 18X7 4-100 40HSM , with 225.40x18Yokohama S.Drive wheels. I would really liketo put 25mm spacers on the back wheels. Can I do that without causing rubbing of the sidewalls? I don't lower the car 'cause it's my everday drive, and I can't afford (not do I want) the air system.
Can anybody help? Ron
Nyuk. Nyuk. Nyuk.
ronsweden is offline   Reply With Quote
Old 11-13-2007, 10:52 PM   #2
joshboogie
joshboogie's Avatar
joshboogie 32/M
Send a message via AIM to joshboogie Send a message via Yahoo to joshboogie
If you don't lower it you should be OK even with a 25mm but a 10mm makes a huge difference.
Scion O.G. with a new name
Modified Minds [Facebook]
Car Audio & Electronics
803-272-8660
Joshboogie [Facebook]
joshboogie is offline   Reply With Quote
Old 11-13-2007, 11:59 PM   #3
ronsweden
ronsweden's Avatar
ronsweden 72/M
Default 25mm spacers on back wheels of a toaster
Quote:
Thanks. I am looking at the 25mm 'cause it seems to be the only one that just bolts on to the existing bolts. I'm not into taking anything apart. Am I right on that? Thanks for the help. Ron
[/img]Click the image to open in full size.
Nyuk. Nyuk. Nyuk.
Old 11-14-2007, 12:12 AM   #4
joshboogie
joshboogie's Avatar
joshboogie 32/M
If you are talking about a 25mm wheel spacer them there is no way you're bolting that on with out having longer studs put it and that would be a HUGE pain to do. If you use a 10mm hub spacer on the rear it will be even with the front. Thats what I'm running in mine now. I have the OTG shims but you can get then from keiko (spelling?). The biggest I've seen is a 15mm shim and that would be more than enough.
803-272-8660
Old 11-14-2007, 12:31 AM   #5
ronsweden
ronsweden's Avatar
ronsweden 72/M
Thanks for clearing that up. Ron
Nyuk. Nyuk. Nyuk.
Old 11-14-2007, 12:33 AM   #6
joshboogie
joshboogie's Avatar
joshboogie 32/M
No problem.
803-272-8660
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
joshboogie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
