Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Forced Induction
Register Forgot Password?
Turbo and supercharger applications...
Reply
Old 11-13-2007, 05:01 PM   #1
Gerard_gmaiz
Gerard_gmaiz 27/M
Default my new 12 psi S/C pulley
i just bought the 12 psi pulley and will instal it tomorow and then to the dyno to setup
but
i"m worried about blowing the engine, i've been running the 7 psi about 4 month , 3000 miles now with no problem my air fuel ratio is 13.3 and i got a good tunner
what you guys think of my chances of blowing the engine?
any info will be great!
Gerard_gmaiz is offline   Reply With Quote
Old 11-13-2007, 05:24 PM   #2
Whocares05050
Whocares05050's Avatar
Whocares05050 26/M
13.3 is too lean
Whocares05050 is offline   Reply With Quote
Old 11-13-2007, 05:39 PM   #3
Butane
Butane 113/M
13.3 is DANGEROUSLY too lean! 12.3 is too lean
Butane is offline   Reply With Quote
Old 11-13-2007, 06:06 PM   #4
draxcaliber
Moderator
Moderator
draxcaliber's Avatar
draxcaliber 27/M
Send a message via AIM to draxcaliber
might need some bigger injectors...and yeah, be safe. don't blow your motor.
Takumi is a Japanese character that symbolizes a broader dimension than quality, a deeper process than education, and a more perfect method than persistence.
draxcaliber is offline   Reply With Quote
Old 11-13-2007, 06:07 PM   #5
draxcaliber
Moderator
Moderator
draxcaliber 27/M
oh yeah, and do you have other stuff like an intercooler, or water/meth injection?
Old 11-13-2007, 06:08 PM   #6
draxcaliber
Moderator
Moderator
draxcaliber 27/M
oh, and there are much better piggyback ecu's than the apexi neo i see listed in your profile. emanage ultimate, aem f/ic, and unichip.
Old 11-13-2007, 06:36 PM   #7
engifineer
engifineer's Avatar
engifineer 37/M
I would have gotten answers to these questions before buying a smaller pulley ;)
If you run 13.3 very far into the throttle, as mentioned, you will be having issues. Especially if you up the boost.
"There is an idiot in every group. Look around... if you don't see one, it is probably you." - Someone paying attention
engifineer is offline   Reply With Quote
Old 11-14-2007, 01:03 AM   #8
kikcaffine
kikcaffine's Avatar
kikcaffine 28/M
Send a message via AIM to kikcaffine
Um the apexi Neo doesnt do a thing for this car A, and B you need a real engine management system or it WILL explode. I dont under stand why you think its an accomplishment to get 3k miles out of it, if you look historically its at about 10k that the blowers will go out if they are going to go. Do you even have a supercharger? I didnt see it listed in your profile mods.....
Nissan Motorsports=Nismo
Honda Motorsports=Homo?
www.superchargedscions.com
kikcaffine is offline   Reply With Quote
Old 11-14-2007, 01:06 AM   #9
draxcaliber
Moderator
Moderator
draxcaliber 27/M
maybe he just got the pulley, and doesn't know he needs the supercharger too! LOL
Old 11-14-2007, 01:07 AM   #10
kikcaffine
kikcaffine's Avatar
kikcaffine 28/M
^ lol it wouldnt be the first time......
Old 11-14-2007, 01:31 AM   #11
06SuperWhite_SoCal_tC
06SuperWhite_SoCal_tC's Avatar
06SuperWhite_SoCal_tC 27/M
I got 20k miles out of my first charger, it was only replaced because a broken braket on the pulley side. The portion of the the pulley side that houses the bearing paked in it. My car overall has been s/c for 30k miles.
TRD SuperCharged: See Profile For Other Mods.
06SuperWhite_SoCal_tC is offline   Reply With Quote
Old 11-14-2007, 01:09 PM   #12
turbo51
turbo51 112/F
lol i blew my motor up at 25psi and when i say i blew it up..im talking like a atomic bomb. so yea dont boost at 25psi
-the turbo tc-
turbo51 is offline   Reply With Quote
Old 11-14-2007, 01:42 PM   #13
krazylowgsx
krazylowgsx's Avatar
krazylowgsx 33/M
Send a message via AIM to krazylowgsx Send a message via Yahoo to krazylowgsx
13.3 is way to lean for WOT! i thought you said you had a good tuner!?!?!?!?!
Facebook.com/turboscions
krazylowgsx is offline   Reply With Quote
Old 11-14-2007, 05:53 PM   #14
jwaggz82
jwaggz82's Avatar
jwaggz82 31/M
Default Re: my new 12 psi S/C pulley
Quote:
but
12lbs s/c building in a strait line is better then a turbo rushing the air in. So with that in mind - I am going to say that it has been done on the s/c and the guy (karl/icenine) did not blow his engine. I do know that the injectors with the s/c max out around 285whp and you never want to be running anywhere near full cycle on injectors. Karl had the s/c cams so thats what put him into the 300whp range (and methanol). I think that you should upgrade your injectors to 5-650's and run methanol if you want to be safer. The fuel pump can remain the same and the stock injectors should work .....but you are surely will be almost maxing out on the cycle for them. Dezod is selling plug and play 750's - They will be more then what you will ever need on the s/c but for the price they will be around the same as 650's. Its surely not going to hurt you ....the injectors will be working less hard. Just make sure you get tuned w/ them on - they are pnp so they will just pop in w/o any cutting.
FOR SALE: Scion tC $5500 w/ engine issues but w/ $5k+ in options
(including limited slip, new pads/tires/rotors): Click Here
FOR SALE - PM ME FOR DETAILS:
1.) 2005 Strupp Header that is Jet-Hot Coated!! $250/shipped&insured!!
2.) 2005 S/C Injectors & Stock tC injectors!! (almost new)
3.) Subwoofers & 4ch amp
4.) 2005 Stock tC exhaust (almost new)
jwaggz82 is offline   Reply With Quote
Old 11-14-2007, 05:54 PM   #15
jwaggz82
jwaggz82's Avatar
jwaggz82 31/M
http://www.scionlife.com/forums/view...r=asc&&start=0
^750 - plug and play injector group buy
Old 11-15-2007, 10:31 AM   #16
Gerard_gmaiz
Gerard_gmaiz 27/M
Oof course i'm supercharged, i haven't edited the profile
the apex neo have worked good to me in the dyno i pulled 217 whp
13.3 is to lean for 7 or 12 psi?
so the answer is do not mount the pulley?
Old 11-15-2007, 11:29 AM   #17
jwaggz82
jwaggz82's Avatar
jwaggz82 31/M
**EDIT**
It was raining horrible ...horrible ... on the way to work and i really couldn't get on it real hard but I would assume almost wot i was at 11
Old 11-22-2007, 07:44 AM   #18
mcclone
mcclone 52/M
Where did you get your 12psi pulley
McClone
mcclone is offline   Reply With Quote
Old 11-22-2007, 09:35 PM   #19
jwaggz82
jwaggz82's Avatar
jwaggz82 31/M
^ he got it from NST (nonstoptuning) - they will make you whatever custom size you want but the wait time is 6-8 weeks so order in advance
Old 11-24-2007, 12:35 AM   #20
mcclone
mcclone 52/M
Thanks for the info
McClone
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
12psi, pulley, scion, tc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
