Remote Car Starter for tC?
Old Dec 3, 2007 | 03:29 AM
tone55loc's Avatar
Default Remote Car Starter for tC?
Am I able to add a remote car starter to my 2008 tC without having to replace the factory keyless entry and alarm system?
Old Dec 3, 2007 | 03:32 AM
UNiT_xEr0's Avatar
DelMarVa
try looking up luxlink.
Old Dec 3, 2007 | 04:19 AM
ppiech2's Avatar
http://www.youtube.com/watch?v=uhECDSc-90g
Old Dec 3, 2007 | 04:43 AM
Jiggaman's Avatar
Big Sky Scion
i would just get an aftermarket setup with alarm, the stock "scion security" is crap
Old Dec 3, 2007 | 06:29 PM
Scott8's Avatar
how much are the luxlink?
Old Dec 4, 2007 | 07:04 AM
Jdub86's Avatar
MN Scions
I talked to a local installer not to long ago about this. You are going to need to leave the valet key in the car in order for the remote start to work. Because without a chipped key the fuel pump won't start.
Old Dec 4, 2007 | 01:30 PM
AKAvensis's Avatar
in the ignition or in the glovebox?
pretty dumb idea to leave a key in the ignition every day
Old Dec 4, 2007 | 10:51 PM
bigdog833's Avatar
Can you put remote in a manuel trans? I have a very strong feeling the answer is no, but not certain.
Old Dec 4, 2007 | 10:56 PM
swiber's Avatar
short answer, yes.
Old Dec 4, 2007 | 11:13 PM
bklyntc's Avatar
i got a remote start on my 07 over the summer and they left everything in
Old Dec 4, 2007 | 11:46 PM
2_much_tc's Avatar
Why would you need to leave the Valet key in the car?
Old Dec 4, 2007 | 11:49 PM
CsmTc_roller's Avatar
You wouldn't I would think. The remote starter bypasses the factory chipped key ignition system, you would just need a key to turn to run to select a gear (auto only) and be able to unlock the steering wheel.
Old Dec 5, 2007 | 12:08 AM
Ace83's Avatar
Ronin Scion
the valet key is placed inside a module that is hidden under the dash (unless you want it in glovebox lol) its risky if the thieves knows where you hide it,if not they might still find it but its gonna take a while.. and yeah you can put it on a manual but its dangerous if you remote start while the car is on gear most shops wont do it on a manual.. and you can always put a bypass so it wont start while the gear is engaged or parking brake is not on.
Old Dec 5, 2007 | 01:20 AM
charlie88's Avatar
it is possible to do a remote start on a manual. its more labor but its possible. i just got a compu star alarm and remote start on my 05 tc about a month ago and i love it.
Old Dec 5, 2007 | 01:54 AM
Jdub86's Avatar
MN Scions
Yeah its possible, usually you have to sign an agreement of some kind. I don't see why there would be more labor.
You need to leave a key in it because there is a chip in the key that allows to car to start. At least thats how it is in the 08.
Old Feb 11, 2008 | 08:55 PM
GQQSE13's Avatar
the reason that you need a key built into the car is for the chip needed to start the car, and you can have it with manual. u just need a bypass....walterego on here has one on his manual
Old Feb 11, 2008 | 09:32 PM
enjoithis's Avatar
any local shop can do it
audiovox 9075, everyone has them.
Old Feb 12, 2008 | 01:13 AM
Kosterfield's Avatar
Like everyone's been saying... It can be done, it can be done to a manual. You just have to make sure you're not leaving the car without the brake engaged if it's a manual.
Old Feb 12, 2008 | 02:41 PM
GQQSE13's Avatar
just watch out. i went to 3 local shops, and they will only install stuff if you buy it there( and they rip the hell outta your @$$ on pricing)
Old Feb 12, 2008 | 10:21 PM
scioncraze05's Avatar
you don't need to leave the key in the car anymore, there is a module out there that does not need the key, its called the XK05 and all you do is program it with your key and thats it, no key left in the car or in a module.
Now a remote start can be done on a tC manual or auto, but you will need 3 extra relays on a manual and 2 extra relays on an auto. The extra relays are for the 2nd ignition wire and 2nd starter wire and the the 3rd for a manual only, is for the clutch bypass.
I would personally recommend a Compustar alarm/remote start system since they have a good rep. and also are legal to put on a manual transmission car.
If you have nay questions I can help, I installed mine myself.
