xA easy street bag setup?
Old Dec 29, 2007 | 12:25 AM
scionxAchic's Avatar
Default xA easy street bag setup?
will an xa lay the frame rails with easy street struts up front and some convoluted bags with bag brackets for the rear?
Old Dec 29, 2007 | 12:53 AM
TerribleTed's Avatar
Nope. The xA setup is essentially the same as the xB setup. With it fully deflated you will be close to the ground but not on the ground. When I fully air out my xB (easy street front and rear installed per the manual) the closest point to the ground with a stock lip is 1 1/2 inchs or so. The underbody (frame really doesnt apply here) is mostly 3 or more inches off the ground. Further modification to the car and suspension is necessary to lay the underbody on the ground. A guy in our club "Bagnasty"has an xA that lays underbody. He did extensive modifications to attain this attitude. Check out his profile https://www.scionlife.com/profile/BagNasty .
Old Dec 29, 2007 | 12:58 AM
oh thanks, I really like that one.
Old Dec 29, 2007 | 07:30 AM
if u remove the sway bar, would the front lay on 17's?
Old Dec 29, 2007 | 11:15 PM
No
Old Dec 30, 2007 | 12:16 AM
do you know what other kind of work would need to be done for the front atleast?
Old Dec 30, 2007 | 02:03 PM
If the strut mounting was moved up in the car a couple inches and the sway bar removed you might get there. That would involve cutting out the strut towers and welding them back in higher up in the car. A taller front front bumper assembly can give the appearance of being lower. The lip on my xB just barely touches the ground when I am aired out. It is about 1.75 inches taller than the stock lip, so it starts out 1.75 inches closer to the ground.
my06tc
Jun 25, 2015 12:18 AM
halosinfire
Scion tC 2G Forced Induction
Jun 10, 2015 05:21 PM
trikkonceptz
Jun 7, 2015 01:46 AM
UberXB
10
Feb 29, 2004 02:50 PM
NemoBronsky
11
Feb 10, 2004 08:07 PM
