What kind of springs is everyone running?
Old Nov 9, 2004 | 09:01 PM
BeQuietAndDrive's Avatar
Default What kind of springs is everyone running?
I would like the Goldlines or RSR springs because they seem to offer the most drop.
However, I'm looking for a good drop as well as a firm ride. I don't care much about ride quality.
What can you guys reccomend? Tein springs seem like they do not drop enough for use with 15inch wheels.
Old Nov 9, 2004 | 09:06 PM
PandaIst's Avatar
I'm running Tanabe DF210's. The drop is really nice...2" in front and 1.8" in rear. :D
Old Nov 9, 2004 | 09:15 PM
How is the handling? Tanabe's are more geared towards comfort,right?
I looked up spring rates for Tanabe DF210's, they are 140 lb/in front, 174 lb/in rear.
RS-R's are 157 lb/in front, 161 lb/in rear.
Both of these seem like nice springs and the Tanabe's drop is nice. I think the Tanabe's are more "comfort" oriented though.
Old Nov 9, 2004 | 09:23 PM
PandaIst's Avatar
Handling is much better than stock. Ride comfort is really good. With the clean aggressive drop it still maintains a smooth ride quality.
Both Rs-r and Tanabe are top notch companies.
Old Nov 9, 2004 | 09:28 PM
Yeah, it doesn't seem like there is too much of a difference in springs rates.
Teins are rated at 150 lb/in front, 180 lb/in rear
Old Nov 9, 2004 | 09:53 PM
manejounxa's Avatar
Im thinking of getting the tein s-tech springs when spring season is here.
Old Nov 10, 2004 | 01:08 AM
GloriousMidget's Avatar
yup s-techs rock (or so i've heard), got mine in, but not installed yet
Old Nov 10, 2004 | 01:33 AM
TakumiJr's Avatar
<-----------Tein S-Tech
Old Nov 10, 2004 | 01:45 AM
djct_watt's Avatar
Team Sushi
TRD's. . . a lot of really fat people ride in my car and I don't want to rub or bottom out. So far I love my TRD's.
Old Nov 10, 2004 | 02:42 AM
hey pandaist do you ever bottom out with yer tanabe's?
Old Nov 10, 2004 | 03:27 AM
cseika's Avatar
ScionERA
I dont' know if you are changing out the shocks and how much your willing to spend. If you absolutely don't care about ride quality and has the $, I would go with the Tein SS coilovers. I had that on my Civic and my friend had that on his MR2. THose things are absolutely firm and amazing, almost 0 body lean! But rides like a skateboard though. That setup would prob run you around 1G.
If thats too much, I have tein S tech on my stock shock. They offer great improvement over stock, and it is def low enough, I'm scraping almost every ramp already, I don't think you want to go any lower than that. Also, if you want the TRD springs and just get the eibach. They are the same!
Old Nov 10, 2004 | 03:35 AM
LeeD's Avatar
Tien H, or S, or both?
I'm also in the market for springs, but don't want a softer ride. I want the same stiffness, if not stiffer.
For those that don't know, the stiffer the string rates are in the rear, the more oversteer you'll get and a more neutral handling car since these cars are set up for heavy understeer.
I've just installed my rear swaybar, and I still could use more oversteer. I'm contimplating installing the rear strut tower along with something along the lines of those Teins. The front to rear ratio and the higher weight rear is attractive to me. Of the numbers given so far, those rears are the heaviest. Although the fr/rr ratio might not be as extreme as the Tanabe's, I don't want too soft for the front either.
Old Nov 10, 2004 | 03:44 AM
Leed,
Those are the rates for S-Tech's. I too noticed the nice stiffness in the rear which looked pretty good.
I am also considering the RS-R springs which have rates of 157 lb/in front, 161 lb/in rear. They seem to offer a nice drop.
S-Tech's don't seem like they lower the car enough but, they are probably more performance oriented than Tanabe DF210's.
Old Nov 10, 2004 | 06:09 AM
PandaIst's Avatar
I have never bottom out on my xA. I don't think it will happen.
Old Nov 10, 2004 | 06:17 AM
phantomxa's Avatar
i'm running eibach pro kit and i scrape my kenstyle lip on a lot of driveways and speed bumps. i dont like the way they look cause the eibachs dont drop much but i couldnt imagine going lower than 2" and not losing my front end.
Old Nov 10, 2004 | 06:39 AM
aireck's Avatar
DF210s on 19's and it rides superb!!!
Old Nov 10, 2004 | 04:56 PM
blimon63's Avatar
i got the s-tech! ^_^
Old Nov 10, 2004 | 05:06 PM
hnefrdo's Avatar
anyone know what the spring rates are for the eibachs?
Old Nov 10, 2004 | 05:10 PM
tCdestro's Avatar
tanabe df210's but not installed yet
Old Nov 10, 2004 | 05:27 PM
LeeD's Avatar
:? ok... and... :?
