Go Back   Scionlife.com » Scion xB Classic » Scion xB 1st-Gen Owners Lounge » Scion xA/xB 1st-Gen Wheel & Tire
Register Forgot Password?
Wheels and tire combinations...
Click Here
Reply
Old 01-23-2008, 12:44 PM   #1
telemike
telemike 46/M
Default P195/60R15 and P185/65R15 tire owners, I need your feedback
P185/60R15's are kinda pricey compared to P185/65R15 and P195/60R15's in my area.
Thinking the the P195/60R15 might be a good alternative as it's just about 2% bigger in diameter and only 10mm wider.
Does the P195 affect gas mileage much? Or is the P185/65R15 a better choice?
telemike is offline   Reply With Quote
Old 01-23-2008, 01:04 PM   #2
monoxide101
monoxide101's Avatar
monoxide101 33/M
I'm running Kumho Ecsta ASX tires in 195/60/15 and noticed no change at all in gas milage. The 185/65/15 is actually taller (3.1% too slow) than the 195/60/15 (2% too slow).
Gasoline, groceries, and our ages
Everything's raisin' but the wages
monoxide101 is offline   Reply With Quote
Old 01-23-2008, 01:13 PM   #3
telemike
telemike 46/M
I can get some Firestone Lemans Champion HR's or Fuzion HRi's way cheaper than P185/60R15's
Champion HR Lemans 195/60R15 H Black Letter/Black Wall 40,000 53.99
HRi Fuzion 195/60R15 H Black Letter/Black Wall 40,000 63.99
FR710 Firestone P185/60R15 T Black Letter/Black Wall 65,000 74.99
HRi Fuzion 185/65R15 H Black Letter/Black Wall 40,000 59.99
PS830/850 Primewell 185/65R15 H Black Letter/Black Wall 40,000 49.99
From Walmart I can get the Uniroyal Tiger Paw Touring T Size: P185/60R15 84T for $60 each.
Old 01-23-2008, 02:42 PM   #4
telemike
telemike 46/M
I just found a good deal on the Tiger Paw Touring P185/60R15 for $310.15 set of four out the door.
Old 01-23-2008, 09:50 PM   #5
Super-Stormtrooper07
Super-Stormtrooper07's Avatar
Super-Stormtrooper07 34/M
Just go to Discount Tire Direct.com , and do a search for 195/60 -15" tires.
A nice Falken ZE-912 tire is $58ea. , free shipping, no tax
http://www.discounttiredirect.com/di...26&rd=15&ar=60
*TRD xA/xB1 front Strut bar, red,$85- shipped
*5Ziegen 15X7 FNOR1-C bronze wheelset$440
* OEM xA/xB1 hub caps,LIKE NEW = $40
*"If your not preparing for the future,you will have no future."
*"Why is it that nobody understands me, and everybody likes me?"-Einstein
*The energy efficency of a bicycle is second only to a bird in flight!
Super-Stormtrooper07 is offline   Reply With Quote
Old 01-23-2008, 09:59 PM   #6
Tim_Carr
Tim_Carr's Avatar
Tim_Carr 42/M
I run the Fuzions on my box, and I will say Wow! They are great! I love mine, my driving would be considered spirited for sure. I like the fact that in good hard turns they will slide lightly without just letting go. Oh yeah I run the 195/60/15's I noticed no change in fuel usage. I did notice that they make the little box feel alot more stable.
Tim_Carr is offline   Reply With Quote
Old 01-24-2008, 02:17 AM   #7
powhound84
powhound84 29/M
yea i just got the 195's for the same reason .185's for some reason cost $15-30 more for less material in a comparable tire. plus, it's a little cushier ride, and a little wider contact patch.
powhound84 is offline   Reply With Quote
Old 01-24-2008, 12:59 PM   #8
telemike
telemike 46/M
This is my wife's Xb so I don't need a drifter tire LOL, something comfortable and gets good treadwear
Old 01-24-2008, 09:44 PM   #9
Pengu56
Pengu56's Avatar
Pengu56 24/M
Send a message via AIM to Pengu56
I've heard the best matches for the stock steelies would be 195/60 and 205/55. You'll have no changes in the speedometer, and you'll have a comfortable ride what with the larger sidewall.
Pengu56 is offline   Reply With Quote
Old 01-26-2008, 05:02 PM   #10
EasysBox
EasysBox's Avatar
EasysBox 29/M
i ran 195 bfg traction ta's before my 19s. i loved them. excellent bad weather tire. i want to say that the oem size for the bb is a 185/65, but i am not certain... either way, it is only a small increase in size, you gas milage will stay the same... check out tirerack.com, great place to shop for tires...
I don't speed, I rapidly accelerate to the speed limit.
EasysBox is offline   Reply With Quote
Old 04-19-2008, 09:35 PM   #11
BayAreaScion
BayAreaScion 30/M
try vulcantire.com Ziex 512 or 912 for $47 a piece and tire-easy.com has Khumo ASX for $38ea and thats P195/60/15
Past Rides: '04 Honda Element, '01 Acura TL, '92 Legend LS, '99 New Jetta GLX
BayAreaScion is offline   Reply With Quote
Old 04-19-2008, 09:37 PM   #12
BayAreaScion
BayAreaScion 30/M
tires-easy.com has the Ziex 512 at $42 a piece!
Old 05-05-2008, 09:38 PM   #13
kile529
kile529 32/F
Hi - new here....and new to making changes to vehicles!
I've found tires that I want....they are 195/60R15....and I've been
told that Walmart won't install them for me because they're not what
my xb "says" I need...... Here's my question - when
you get tires online....and you need them installed - who do you get to
install them for you?
kile529 is offline   Reply With Quote
Old 05-07-2008, 05:56 AM   #14
Howdy there.
When your new tires get delivered to your front door, put them in the back of your vehicle- they will fit in there just fine. Then, go down to your local Tire store (look in the phone book , and see who is local for tire shops) - it might be good to make an appointment , but most dont require that you do so. They will install them for you for right about $40-60 mounted and balanced. IF you want nitrogen (instead of regular air) , its about an extra $4-5 per tire ( the only real benifit is that the nitrogen doesn't leak out nearly as fast as regular air, since Nitrogen has larger molecules).
hope this helps
Old 05-07-2008, 06:00 AM   #15
PS.. forgot to add, but if COST per tire is important to you, yet getting a quality tire is also important, you should be able to get a good 195/60/15 through Discounttiredirect.com for right about $60-65 per tire( Falken I believe). Tires easy has some good deals as well, but with shipping I think they are pretty close to discount tire direct, right about $55-65.
Old 05-07-2008, 12:50 PM   #16
kile529
kile529 32/F
Well - I called BelleTire in my area to see if they would install the tires for me when they're delivered...and the guy said (without knowing my price) that he was going to beat it. So...I got 4 tires 195/60/15's installed w/ Nitrogen....and have the warranty & free repairs if needed for $237.44. Just to get the tires shipped to me was $240....then adding install....so I went right up an bought 'em! I drive back country-dirt roads a lot so it doesn't matter the "quality" really - I tear through tires like nothin'. Our local tire shop stopped selling us the great brands because he knew it wouldn't matter. lol Anyways - thanks for all your help! I wouldn't have known I could get a different size if it weren't for all of ya! Thanks again!
Old 05-08-2008, 04:37 AM   #17
Your welcome... sounds like it worked out well then!!!
Yes, tires are kinda like toilot paper , hey its a consumable.
Old 05-08-2008, 06:25 AM   #18
bB2NER
Music City Scions
bB2NER's Avatar
bB2NER 109/M
Send a message via Yahoo to bB2NER
Yeah but what brand tire did they sell you?
Jeff
05' BCP xB W/ 48K miles
08' Absolute Red Yaris LB 5spd. W/ 42K miles
bB2NER is offline   Reply With Quote
Old 05-08-2008, 11:40 AM   #19
kile529
kile529 32/F
Sunny....lol....I'm fine with it....it doesn't seem to matter what "brand" I get....I tear through them and need to get new tires again after about two years.
Old 05-08-2008, 01:50 PM   #20
Sciond
Assistant Admin
Assistant Admin
Sciond's Avatar
Sciond 17/F
Send a message via ICQ to Sciond Send a message via AIM to Sciond Send a message via Yahoo to Sciond
some people have lower expectations....and are willing to assume risk....
"You are not Sancho"
2010 MB ML350 Bluetec
2013 Ford Explorer Sport... Tune coming
2013 Wrangler Unlimited Sahara
Twitter:@sciond/facebook:sciond
There is no new Scion I can buy that fits my needs....
Sciond is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
60r15, champion, hr, lemans, p185, p1956015, p19560r15, perform, primewell, ps830850, reviews, scion, tc, tire, tires, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
