Exhaust Leak?
Old 01-30-2008, 03:19 AM
silvrxb's Avatar
Default Exhaust Leak?
I'm going to install my exhaust myself. How do i check to see if it is leaking after install? I bought a torque wrench/ratchet (whatever) so that i tighten everything correctly.
silvrxb is offline
Old 01-30-2008, 03:28 AM
CIONIDE's Avatar
If you pass out from carbon monoxide while driving, then it is leaking.
CIONIDE is offline
Old 01-30-2008, 05:02 AM
Velocitysport31's Avatar
just make sure everything is snug, you will hear the leak if you have one. you really dont need a tork wrench, just a good rachet.
Velocitysport31 is offline
Old 01-30-2008, 05:19 AM
draxcaliber's Avatar
start your car, plug up the exhaust tip, if it stalls out, your exhaust is sealed, if it leaks, it will continue to rum.
draxcaliber is offline
Old 02-02-2008, 01:38 PM
chadfo's Avatar
I don't think I'd try this method. That pressure has to go somewhere and back through the engine is not good.
After installing the exhaust start the car and move your hand around the connections. Do this quickly after starting the car so if you accidentally touch the exhaust it will not burn you. If it's leaking you'll feel the gases pushing out and in many cases you'll hear them.
chadfo is offline
DaBlackBox
134
04-10-2022 02:04 PM
eric29
15
04-26-2016 07:27 PM
Andreas24
05-17-2015 09:05 AM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
Quick Reply: Exhaust Leak?
