xB cruise control install problems! Those w/cruise Help! Pic
Old Nov 11, 2004 | 01:36 PM
tcm_xB's Avatar
Default xB cruise control install problems! Those w/cruise Help! Pic
Can someone tell me if I have the cruise / throttle body connection right?
Is the bracket suppose to be on the side with the red outline? I also think I f**ked up by loosening nut 1 and not number 2:
Also, can someone tell me if the throttle cable has some slack in the line? I think mine may be a little to loose now, but not sure.
The pictures in the instructions I have are so damn $hitty!!!
Old Nov 11, 2004 | 01:51 PM
tcm_xB's Avatar
Default Power at fuse box drivers side...
How the hell do you get to the back of the fuse panel to insert the brown power wire with the 1,000,000 wires in the way????
Did you guys remove the entire fuse box so you could face the wiring toward you?
Man, I am ready to take the $hit out and sell the damn thing
Old Nov 11, 2004 | 02:09 PM
tcm_xB's Avatar
Help?!?
Old Nov 14, 2004 | 03:21 PM
Kong's Avatar
bump! I don't have a cruise control.
you should take a look at some of the input from the allscion.com website?
http://www.allscion.com/cruisecontrol_remarks.html
Hope this help
Old Nov 14, 2004 | 04:22 PM
boilerman's Avatar
I doubt this will help but maybe.
http://www.allscion.com/cruisecontrol_manual.html
Old Nov 16, 2004 | 12:04 AM
superjeer's Avatar
lol, I checked mine, which is a retro fit, so it's not the source of truth, but the hand made bracket on mine looks to be in the same position as yours.
Also, there's not slack, but I can deflect the cable 1/4" either way without much pressure at all.
Finally "back" of the fuse panel.?
try pushing up on the backside of the little cubby in front of the fuse block (down by the hood release).
https://www.scionlife.com/forums/viewtopic.php?t=29238 has a pic of what I'm talking about. (it's under a "TOOLS" heading.)
Old Nov 27, 2004 | 05:35 PM
tcm_xB's Avatar
Ok, I'm finally over the flu and back to this $hit!
Just snapped a picture of the fuse panel with the cubby pocket removed:
What I see in the picture of all the fuses / relays and whatever the hell else is there does not match up with the $hitty drawings in the instructions.
The place(s) where I tap in. Can you see them in the picture?
tcm_xb: wishes this came installed with the car
Old Nov 28, 2004 | 02:35 PM
SmartAss's Avatar
I can check it out on monday when I unpack.
Old Nov 30, 2004 | 01:25 PM
tcm_xB's Avatar
Over 200 views and not much help :?
xB is for sale in the classifeds if interested
Old Nov 30, 2004 | 03:41 PM
superjeer's Avatar
do you have a test light? You want a power supply that comes on with the key, but off when the key's off.
Old Nov 30, 2004 | 05:20 PM
tcm_xB's Avatar
I know what I need to tap into. Just don't know where it's at....
Old Nov 30, 2004 | 05:50 PM
superjeer's Avatar
so, I take it you don't have a tester?
http://www.bradytools.com/circuittester1.html
Old Nov 30, 2004 | 07:57 PM
SmartAss's Avatar
What wire are you trying to get?
If you jsut trying to get ignition or battery go straight to the ignition harness near the key cylinder.
Old Nov 30, 2004 | 10:51 PM
tcm_xB's Avatar
I'm trying to figure out the complete wiring of the cruise. The instructions tell what pins to tap into for power, but I can not find them in the car....
I do not have a test light. I have a multi-meter if that matters
Old Nov 30, 2004 | 10:53 PM
SmartAss's Avatar
How about make a list of the wires you need...... post them and it will be easier to help you.
Old Dec 1, 2004 | 07:13 PM
romhog's Avatar
ok so mental note to self, just have dealership install mine when I go to pick it up.
Old Dec 1, 2004 | 07:19 PM
superjeer's Avatar
Yeah, if you know you need switched power or constant power or low power only on Tuesdays... let me know and I'll use MY tester, but yse, your multi meter will work. IT should tell you when you have current (and it's all 12v current).
Old Dec 1, 2004 | 10:58 PM
tcm_xB's Avatar
Ok guys.....
Here are the instructions that came with the cruise:
http://www.toyotaparts4u.com/0001679910xAxBCruise.pdf
Page 7 which is for the wiring for the cruise control. All those fuses / relays, whatever the hell they are..... I do not know where they are..... Are they in the pic above (in this thread) that shows the fuse panel?? If not, where are they????
Thanks!
Old Dec 1, 2004 | 11:25 PM
SmartAss's Avatar
Umm ok so brown wire tap it to the wire in the black plug on the back of the fuse box..... xa Grey xb Black/White
Is that all you need?
Old Dec 2, 2004 | 01:57 AM
tcm_xB's Avatar
Where is the "back plug" that is located on "the back of the fuse box"? Seriously, I look behind the fuse panel (pic above) and see 50,000 wires in bundles......
