will this tire fit the stock rim???
Old Nov 13, 2004 | 06:45 AM
Soon2BxB's Avatar
Default will this tire fit the stock rim???
So i was browing tire rack looking for some good all seasons .. and came across a kuhmo that gets awesome reviews...
problem is .. the people claim that the tires are too narrow for the size they claim .. so they are saying go one size bigger...
i planned on running a 185 65 15" ....
but would a 195 65 15" fit ?
I already know the 65 series over the 60 (stock) will fit
but will the 65 height with the 195 width on the stock rim work ? - thanx alot
tom
Old Nov 13, 2004 | 07:25 AM
squirrel's Avatar
Yes, it'll be a tad bit taller though.
Old Nov 13, 2004 | 08:01 AM
Soon2BxB's Avatar
thanx for the quick response ...
taller is ok with me ... especially for tires that i am going to roll for the winter...
Old Nov 13, 2004 | 04:05 PM
squirrel's Avatar
You're welcome. That's what we are all here for.
Old Nov 15, 2004 | 06:55 PM
TakumiJr's Avatar
It should work, I'm picking up Yokohama AVS ES100. Which are 195/60/15
Old Nov 16, 2004 | 10:42 PM
RogerTTR's Avatar
Our fitment team is recommending the following 15" fitments for the xB, the 195/65R15's at 25.0 inches in diameter will more than likely be a little tall for the xB.
Tire Size / Overall Diameter
185/60-15 / 23.7"
195/55-15 / 23.4"
205/55-15 / 23.9"
215/50-15 / 23.5"
Old Nov 16, 2004 | 11:05 PM
Soon2BxB's Avatar
185/60-15 / 23.7"
195/55-15 / 23.4"
205/55-15 / 23.9"
215/50-15 / 23.5"
even if they are a bit taller .. explain why they wont work ?
what is the size of a 19" rim and a 215 35 19" tire ? ...
there seems to be plenty of clearance to fit the 195 65 15 ... can someone confirm for sure if they will fit
Old Nov 17, 2004 | 04:02 AM
djct_watt's Avatar
Team Sushi
your speedo will be off. . . that should be about it. . . assuming the width is suitable for a 5.5" wide rim
Old Nov 17, 2004 | 05:13 PM
George's Avatar
Our fitment team is recommending the following 15" fitments for the xB...
How does this "fitment team" determine the tires they recommend? Do they actually try the tires on the car, or do they simply select tires that are close to the stock diameter?
Old Nov 17, 2004 | 08:14 PM
Soon2BxB's Avatar
i have also wondered this ... they say a 215 wide tire will fit .. on a 5.5 inch wide rim ? im having a hard time believing that
i think ill take your guys advice and go with the 195 65
Old Nov 17, 2004 | 11:25 PM
squirrel's Avatar
I personally wouldn't run a 215 wide tire ona 5.5 inch wide wheel. But that's just me. I don't know anything.
Old Nov 19, 2004 | 12:38 AM
irv_usc's Avatar
fitment team = tire size calculator
the tire you asked about is a bit tall, so your speedo will be off by more than usual. just keep that in mind when you're driving around.
Old Nov 19, 2004 | 01:12 AM
George's Avatar
The speedo already reads high, so taller tires will tend to make it more accurate!
Old Mar 22, 2010 | 11:47 PM
Runks6's Avatar
will a 175/60/15 tire fit on the stock xa rim?
Old Mar 23, 2010 | 05:22 AM
burstaneurysm's Avatar
Yes, and thanks for bringing back one of the oldest threads here.
scionlife
371
Jun 2, 2015 11:00 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
TJ
10
Apr 15, 2006 05:12 PM
