Check engine Light Still.......
Old Feb 20, 2008 | 05:54 AM
Seattle_Tc's Avatar
Default Check engine Light Still.......
Ok so here it goes
Bought a tc had a check engine light on
took to a dealer and they said the MAFS was messed up because of a crappy intake system the previous owner had put on.
So put on a injen intake and new MAFS. Still have check engine light on.
Do I have to reset the light? or does it do it automatically?
Old Feb 20, 2008 | 05:57 AM
7thgear's Avatar
your best bet would be to disconnect the negative battery terminal so that the ecu resets.
Old Feb 20, 2008 | 06:06 AM
Seattle_Tc's Avatar
ill try that
Old Feb 20, 2008 | 03:00 PM
hawgs74's Avatar
Disconnect MAF
Disconnect Neg Terminal
Wait 15mins or so.
Reconnect Battery
Reconnect MAF
Start the car and let it idle for atleast 10mins to let the ECU re-learn
if that doesnt work you need to take it to the dealer and have them reset it with the TIS machine
Old Feb 20, 2008 | 06:55 PM
Seattle_Tc's Avatar
Ok so the light went off after I reset the Ecu. Thanks!
Now i just have a maitenence light on ...
Old Feb 20, 2008 | 07:59 PM
hawgs74's Avatar
Just turn it off
Old Feb 20, 2008 | 08:18 PM
GQQSE13's Avatar
maintenance one i found out is the oil change one. if you hold in the "mileagereset" button and turn your car off, keep holding it and turn it to "accessory" and watch the numbers drop to 0. (takes like 6 or 7 seconds) then when you turn it back on it will be off. i just found that the hard way from driving to the dealer
Old Feb 20, 2008 | 11:09 PM
R2D2's Avatar
^ yeah, supposedly it appears every 5K mi.. There's also the tire one in the glovebox..
Old Feb 21, 2008 | 01:34 AM
GQQSE13's Avatar
^^^ ya i hate the tire one especially during the winter. but once i get my aftermarket rims on it'll stay on all the time since i wont replace censors
Jordly221
Feb 13, 2019 05:29 PM
Miqmiqmiq
Apr 16, 2016 02:34 AM
daniinpitt
Apr 4, 2015 08:07 PM
Bakoscion46x
Jan 19, 2015 02:39 AM
AdmirN
Jan 5, 2015 10:19 PM
