Go Back   Scionlife.com » Scion xB 2nd Gen » Scion xB 2nd-Gen Owners Lounge » Scion xB 2nd-Gen Drivetrain & Power
Register Forgot Password?
Reply
Old 03-03-2008, 04:04 AM   #1
08xB714
08xB714 34/M
Send a message via MSN to 08xB714
Default where's the clutch fluid reservior
i'm a honda guy and it is very weird that i don't see clutch fliud reservior.
how do you guys change clutch fluid? or bleed?
also, i notice in the maintenance manual that there is no information as to flushing out the brake fluid nor clutch fluid.(which it should be.. every 15k-30k)
Honda noob..
08xB714 is offline   Reply With Quote
Old 03-03-2008, 02:27 PM   #2
MikeInABox
MikeInABox's Avatar
MikeInABox 31/M
I'm not 100% sure, but it might use the brake fluid reservoir for the clutch also. Not sure how many companies do that, but my old car was that way.
2005 STi
Scikotics: West Virginia Chapter
MikeInABox is offline   Reply With Quote
Old 03-03-2008, 04:44 PM   #3
08xB714
08xB714 34/M
clutch & brake using a same reservior... very weird... so is that mean, i need to bleed clutch & brake at same time?
Honda noob..
Old 03-03-2008, 05:36 PM   #4
MikeInABox
MikeInABox's Avatar
MikeInABox 31/M
Yeah they both use brake fluid, so one reservoir, two different cylinders(one for clutch, one for brakes). I did a quick search and the tC only has one. Even found a good story where a Toyota tech told a tC owner they had two seperate reservoir's, and then couldn't find the clutch one under the hood when he tried to show them, because it wasn't there. So I'm assuming ours are the same. But if I'm wrong, don't worry, someone will let us know.
As for bleeding them, it's probably a good idea to do them both at the same time. Otherwise you might end up chasing a problem back and forth trying to eliminate air bubbles.
2005 STi
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
04, 07s, 08, 2005, 2007, 2008, clutch, fluid, location, oil, put, reservoir, resevoir, scion, tc, xb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Statement - Terms of Service - Jobs
vBulletin® v3.8.7, Copyright ©2000-2014, vBulletin Solutions, Inc.
