New Tires & Rims -Steering Wheel Shakes at Highway Speed
Old Jan 10, 2004 | 01:56 AM
bobbyboshay's Avatar
Default New Tires & Rims -Steering Wheel Shakes at Highway Speed
Hey Everyone, I just had Tenzo Type C rims 17's with Dunlop SP Zr Tires installed 215/45/17. Offset 40. The guys said they used a spacer on front wheels because rim was touching caliper. My problem is steering wheel shakes when I'm going about 70. On some parts of the freeway it's fine but on others not good . It looks like they used a 1/4 inch spacer. Any suggestions? Re balance rims ,change spacer . Any suggestions would be appreciated.
Thanks
Bob
Old Jan 10, 2004 | 01:59 AM
DJ_SpaRky's Avatar
Did they install Hubcentric Rings??
If not that'll prolly fix that right up.
Old Jan 10, 2004 | 02:01 AM
BlueBox's Avatar
Default Re: New Tires & Rims -Shimming at Highway Speeds
Thanks
Bob
interesting... the tire might not be balanced correctly or the spacer might have something to do with it.
i have 215/45/17 with 40mm offset as well... and i have no spacer..and no rubbing at all.
i suggest u take it back and see what they can do to adjust it. shaking of rim is not normal and can be a safety factor.
Old Jan 10, 2004 | 02:30 AM
westsype's Avatar
So Shinny! But we can't see them.
Old Jan 10, 2004 | 02:32 AM
showpaojoe's Avatar
IV ACE
check the rotor, thaz what did it on my other car
Old Jan 10, 2004 | 02:48 AM
Whats a Hubcentric Ring?
Old Jan 10, 2004 | 03:58 AM
arinvolvo's Avatar
bobby, see if it is balanced in two places.
Crappy wheel mounting places will balance the wheel in one location
Good places will balance the inside AND the outside of the wheel....
I HAD THE EXACT SAME PROBLEM AS YOU!!!
Was completely fixed by having a different place balance them correctly, the inside and the outside.
Old Jan 10, 2004 | 11:30 PM
That's the missing piece, should be in on monday.
Old Jan 11, 2004 | 12:05 AM
yanges's Avatar
sounds good! now when can we see some pics?
Monkey343
Nov 10, 2016 02:07 PM
kleecker
May 22, 2016 06:10 AM
Yakimaniac
Scion xD Wheel & Tire
Nov 22, 2014 04:20 PM
Besk_one
Oct 18, 2003 08:41 PM
ChickenAdobo
Oct 16, 2003 03:57 PM
