xB fog light alternatives
Old Nov 18, 2004 | 10:22 PM
OKIHost's Avatar
Default xB fog light alternatives
Seeing as the stock foglights do not really help at all driving at night eevn though they do look cool I have bad eyes and I am looking for an alternative to the stock fogs that look good and will help me see at night, I would also like something that is fairly easy to install.
can some people post pictures of your alternative foglight setup, where you got them and how much you paid, I really liked these https://www.scionlife.com/forums/viewtopic.php?t=34645 but I am not sure which ones they are or where to find them. They look like it would be hard to mount them to the mesh stock grill down below.[/url]
Old Nov 18, 2004 | 10:24 PM
BoomBox757's Avatar
DelMarVa
have you thought about HIDs if you ahve trouble seeing
Old Nov 19, 2004 | 01:59 AM
OKIHost's Avatar
Yeah I was actually thinking about it but I hear so many problems and with it being a brand new box I dont want to risk having any problems. I did get a nice set of PIAA bulbs and it has helped quite a bit they look great but a little more light could never hurt and I think it would help. I live in the sticks now and when I say sticks I mean interstates and almost all roads have no lighting at all.
Old Nov 23, 2004 | 08:03 AM
panasoanic's Avatar
The PIAA bulbs are actually worse than stock, I'm sorry to say. http://www.overboost.com/story.asp?id=102
If you want some auxillary driving lights, I suggest buying a pair of Hella Micro DE in the driving light pattern NOT the flood beam pattern. Unlike the cheap crap you'll find in walmart, these lights actually perform. If you have the money, you can even get the driving lights in HID.
http://www.rallylights.com/hella/Micro_DE.asp
Old Nov 25, 2004 | 02:44 AM
OKIHost's Avatar
wow man that is a great read, it is funny to find that everything is just in our heads about buying the expensive bulbs. I can say that the PIAA are 'whiter' when I drive but obviously they do not out-perform like I thought.
Unfortunately I do now have $700 to spend on running lights so I am thinking the JDM stock ones may be my next best bet.
Old Nov 25, 2004 | 04:07 AM
BoomBox757's Avatar
DelMarVa
oooo ooo get HIDS with high and low beam. but get the ones that are like 18K not the normal 4K
Old Nov 25, 2004 | 02:21 PM
uncompiled's Avatar
I hope you're kidding about an 18K HID conversion. ;)
Old Nov 25, 2004 | 06:38 PM
BoomBox757's Avatar
DelMarVa
noway they would be so bright it would be awesome!!!!
I don't know were to get them though, the highest I've found are 10000
Old Nov 25, 2004 | 09:54 PM
panasoanic's Avatar
Most manufacturer's lights do little to light up the road. European aftermarket companies such as Hella and Bosch, however, do actually perform.
Driving lights have to be mounted at or above the headlights to be effective. Foglights have to be mounted as low and close to the ground to be effective. If I were to mount driving lights on an xB, I would try mount them right before the grill. Since that is a larger opening, I believe the Bosch Sport Compact 100s would be an excellent choice.
If you are serious about adding driving lights, go ask a question to Daniel Stern. He is a photometric engineer and runs a automotive lighting supply company. He can tell you more about the various options you have for your xB and can import the European stuff that isn't readily available in the US. http://www.danielsternlighting.com/
Old Nov 26, 2004 | 07:10 AM
fireballfish's Avatar
you understand the 4000 in the number on the kits is refering to the temperature in Kelvin of the arch in the HID bulb, right? 4300 is the Ideal temerature, andything higher deviates from white light and thus looks blue or purple. a 10000 kit would actually produce fewer lumens than your stock halogens.
Old Nov 26, 2004 | 02:25 PM
BoomBox757's Avatar
DelMarVa
ohh no I didn't, so what tells you if its brighter?
Old Nov 26, 2004 | 02:53 PM
lowbox's Avatar
hey that is my box in the link . the driving light's are BRIGHT , i have people flash there light,s at me to turn them off. now don't laugh but they are from WAL MART and cheap , they are called PRO BURNER'S cost about $20.00 . I ordered the relay & switch that come with the stock driving light kit, the switch & relay cost about $80.00 from the dealer, then i wired the light's in to the plug's under the hood, so they go off when you switch to high beam's
Old Nov 26, 2004 | 03:34 PM
BoomBox757's Avatar
DelMarVa
you should have left it so it was on with the high beams, that way when people flash you for it, you can flash them with the lights and your highbeams, and they would be like OMG those are some bright lights
Old Nov 26, 2004 | 03:42 PM
lowbox's Avatar
I did that at first , but the local cop's didn't seem to like it and told me i should fix it :?
Old Nov 26, 2004 | 09:37 PM
that's a good question.... most HID companies will put the temp, but not the lumen output... Lumens is a measurement of light 1 lumen is equal to about one candle power.
Old Nov 26, 2004 | 09:38 PM
your driving lights probably are just aimed too high.
Old Nov 26, 2004 | 10:36 PM
BoomBox757's Avatar
DelMarVa
so what do you think are the brightest ones on the market?
Old Nov 26, 2004 | 11:13 PM
as a reference 5250°K is the temp of the light at noon, anything higher will deminish the light output as it would deviate from "white" light. I would say anything from 4000 to 6300 is the brightest, If your area cops are ****, I would get a 4.3 kit, it's much brighter, but doesn't look too blue.
Old Nov 27, 2004 | 02:35 AM
BoomBox757's Avatar
DelMarVa
I ment as far as the lumen goes?
Old Nov 29, 2004 | 09:22 AM
mD5's Avatar
mD5
you want higher lumens. 1 lumen = 1 candlelight. the kit in my car is a OEM Audi RS6 ballest and starter etc. it has a purpleish tint to it but most european market cars use hella ballests and the such. thats why i believe my lights are brighter than the white one. i just think his headlights are aimed inproperly.
