Can't find the ECU Pinout :(
Old Mar 12, 2008 | 01:57 PM
oldred's Avatar
Default Can't find the ECU Pinout :(
Hi everyone,
I couldn't find the ECU pinout for my 2003 Camry (the Camry forums didn't do me any help)
It's the same 2AZ-FE engine, but not the same ECU.
I've been Searching for a week now...
Help
___
Old Mar 12, 2008 | 02:39 PM
bkuhl's Avatar
http://rapidshare.de/files/23267350/02EWD.pdf.html
Old Mar 12, 2008 | 03:30 PM
oldred's Avatar
"file not found"
Old Mar 12, 2008 | 03:39 PM
bkuhl's Avatar
I'll see if I can dig it up when I get home. That site is blocked here at work.
Old Mar 13, 2008 | 01:07 PM
oldred's Avatar
find anything yet? i'm counting on you buddy
Old Mar 13, 2008 | 01:10 PM
lastlookcustoms's Avatar
What do you need exactly? which wires are you lookin for specifically?
Old Mar 13, 2008 | 01:38 PM
bkuhl's Avatar
nope, I don't have access to the doc lib anymore. I had a link to the 05EWD but no dice, sorry. I tried contacting GReddy, but they just pretty much laughed.
Old Mar 13, 2008 | 01:43 PM
GReddy is NEVER any help. Let me know exactly which wires you are looking for. I have the diagram in front of me right now.
____
Old Mar 13, 2008 | 02:22 PM
bkuhl's Avatar
What you doing in Saudi oldred?
Old Mar 13, 2008 | 02:35 PM
bkuhl's Avatar
llc;
He's trying to connect a S-AFC Neo up to his 5gen Camry.
Old Mar 13, 2008 | 02:49 PM
Alright so probably RPM, ign, ground, TPS, Coils.... Anythng else ya think?
Old Mar 13, 2008 | 03:23 PM
Alright, here ya go guys.. let me know if you need anything else
RPM - E10 Connector, pin 27 Color - RED
TPS - E10 Connector, pin 21 Color - Light Green
Coil #1 - E10 Connector, pin 8 Color - Red/White
Coil #2 - E10 Connector, pin 9 Color - Pink
Coil #3 - E10 Connector, pin 10 Color - Light Green/Black
Coil #4 - E10 Connector, pin 11 Color - Blue/Yellow
12v Constant - E6 Connector, pin 3 Color - Black/Yellow
12v Switched - E6 Connector, pin 1 Color - Black/Red
Air/Fuel - E9 Connector, pin 23 Color - Orange
Injector #1 - E10 Connector, pin 1 Color - Blue
Injector #2 - E10 Connector, pin 2 Color - Red
Injector #3 - E10 Connector, pin 3 Color - Yellow
Injector #4 - E10 Connector, pin 4 Color - White
These should be 100% accurate, but please test them to make sure first.
Old Mar 13, 2008 | 03:38 PM
bkuhl's Avatar
should be it. was going to add Air/Fuel but you threw that in on the breakout.
Old Mar 14, 2008 | 09:53 AM
oldred's Avatar
This is for the tC? It's not the same as the Camry, I have the wiring diagram for the tC and the Estima (same 2AZ-FE engine), the three cars have three completely different ECUs.
I'll give it a try right after i fix the damn thing, the car doesn't start anymore... it's dead. have any idea what the problem might be?
_____
Old Mar 14, 2008 | 09:56 AM
oldred's Avatar
I think i'm gonna be needing a new ecu...
so much for fuel system upgrade
thank you all for all you efforts
Old Mar 14, 2008 | 12:05 PM
That is for the 2003 Camry with the 2AZ. NOT for the tC.
Old Mar 14, 2008 | 02:06 PM
bkuhl's Avatar
*shrug* I guess people don't wnat the help that they seek
Old Mar 19, 2008 | 08:43 PM
oldred's Avatar
Maybe for the US version. Mine is "Gulf Specs", some of the wires differ in color. Thanks though.
____
Old Mar 19, 2008 | 10:14 PM
bkuhl's Avatar
Originally Posted by oldred
Mine is the "gulf spec"
you left that part out...
rafa
Toyota Echo Owners Lounge
Jul 22, 2008 09:28 PM
pralexisxb05pr
Oct 24, 2006 02:52 AM
Chinaone
Feb 1, 2006 12:09 AM
B1uEsC1uEs
16
Jul 6, 2005 03:38 PM
WAFFLES
Nov 25, 2004 12:56 AM
