Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Drivetrain & Power
Register Forgot Password?
Reply
Old 03-15-2008, 08:19 AM   #1
Darken
Darken 28/M
Default Adding Cruise and Wheel Controls To a SPEC! HELP?
Hello all. FIRST post here! I really need some help. I just got a 2007 FM spec tc (yes its a spec, and yes i love it) And im starting down my list of mods starting with what I can afford. I got a steering wheel with cruise control and audio controls and an airbag to match. If this little thing works, i will have gotten the only option i really want and will not be changed anyway by the time my mod list is done.
I had no idea if the new airbag would clip back into the harnesses i had but the switch took litterally 2 min. Now if i can get the other stuff working i will be a happy camper.
I need to hear from someone who knows how i can add cruise control. I talked to a guy that works on industrial toyota equipment and fleet vehicals and he said because everything is electronically controlled i may just need an upgrade to my ecu but he has no idea. I don't think i want to risk getting an aftermarket one if i can help it, and infact does the aftermarket systems work for a drive by wire car? THANKS IN ADVANCE!
-JJ
2007 Scion TC Spec. Yeah thats right. SPEC... AND I LOVE IT
Darken is offline   Reply With Quote
Old 03-15-2008, 08:55 AM   #2
SquallLHeart
Super Moderator
SuperMod
SquallLHeart's Avatar
SquallLHeart 29/M
Send a message via AIM to SquallLHeart
i never got the chance to look at it in detail, but though i know the cruise control may screw and plug in easily, i don't think the necessary wiring is there to go back to the ecu.
maybe, maybe not. but with how easy it is to plug in, you can try to see if it works... but uhh... is there an empty hole for it to go thru?
i don't remember seeing one...
please??
the source of original LED ideas - swap expert - parts available Become a fan! LED-Headz
need 2nd GEN tC info? disassembly? questions? i got most of it down.
need help? call me: 408-905-7769
me like:
Doctor Isotope | PrecisionMuffler | 365motorwerks | LEDmod.com(custom Gaugefaces)
SquallLHeart is offline   Reply With Quote
Old 03-15-2008, 09:03 AM   #3
Darken
Darken 28/M
Next to where the airbag wires come out of the steering column there is a harness that the audio and cruise controll connects. in my spec, the only wire coming out was a blue that slid onto the airbag. (for the horn i think) SO the harness is there, but the wires probably don't come out the back. I can splice them into the harness but i gotta know what to connect them to and if it would work. Thanks for the reply by the way!
Old 03-15-2008, 09:30 AM   #4
SquallLHeart
Super Moderator
SuperMod
SquallLHeart 29/M
the cruise control that you got doesn't have just a new plug that plugs right in, replacing the one that just has the (yes.. it's the horn wire) one wire..?
the thing is does it continue out the other end o the spiral cable and to the ecu.. that's what i don't know.
please??
me like:
Old 03-15-2008, 07:57 PM   #5
Darken
Darken 28/M
yes it does have a new plug that replaces the old one. (including the blue wire) But Yeah what i need to find out is if it does infact connect to the ecu. Maybe there is a wiring manual for the Spec? any one know or know how to find out?
Old 03-17-2008, 03:10 AM   #6
Darken
Darken 28/M
anyone know where i can get a spec wire guide?
By the way, new airbag + 100 miles = no airbag light. Seems to have worked like a charm. Now if i can get the cruise and radio controls i will have saved a crap ton of cash
Old 03-17-2008, 07:08 AM   #7
3min3m2
3min3m2 25/M
good luck man, im guessing the wiring should be there....
3min3m2 is offline   Reply With Quote
Old 03-17-2008, 08:40 AM   #8
SquallLHeart
Super Moderator
SuperMod
SquallLHeart 29/M
i'm guessing not.
it's easy for the factory to build one without those particular wires... (esp. for the radio controls)
radio controls, you'd probably need to make a harness yourself...
but the cruise control... very, very iffy. i'm thinking no.
please??
me like:
Old 03-17-2008, 10:13 AM   #9
divisii
divisii's Avatar
divisii 72/M
From my past experience... it's better to start with what U want than it is to add it later. I'm thinking the manufacturer made it impossible to add cruise ... I read somewhere that you'd need a different throttle body/electronics. With this drivebywire stuff, I'd also not be surprised if this mod would req. an ECU.
Interesting to know how this turns out, goodluck & please let us fellow Spec ownrs know, k?
SW 08 Scion tC Spec 5spd
K&N, mudguards, custom front lic. plate, Doc.Iso. radiator plate & valve cover...
divisii is offline   Reply With Quote
Old 03-20-2008, 07:38 AM   #10
Darken
Darken 28/M
thanks for the info so far. It looks like this topic has been posted in other areas now... Any one made any headway on finding a wire diagram? And yeah yeah i know i shoould have got the normal tc but i got it used (with 10,000 miles) and it was the only one in the color i wanted (FM) and you know what? Im totally over not having the normal tc. I wish i had known it was going to be such an issue to add cruiz so i would have saved some time and money buying the the other wheel but over all i think it was a good purchase. I figured it would be possible for a few hundred bucks but i still really think i can get the controls to work. Even if its only when i replace the radio with an aftermarket. but i probably will have to do some fancy wiring to get it working. oh well.
sorry for the rant.
Wire diagram?
Old 03-20-2008, 08:54 AM   #11
tico4csun
Team ScionTific
tico4csun's Avatar
tico4csun 34/M
Send a message via AIM to tico4csun Send a message via MSN to tico4csun Send a message via Yahoo to tico4csun
Has this been installed yet?
Otherwise if too risky, maybe just keep what you have now and keep that airbag. May prove to be a pain
I was thinking of addin a paddle shifter system to my auto tC. But then the tranny has to be reprogammed and that will will cost to much money.
tico4csun is offline   Reply With Quote
Old 03-20-2008, 11:02 PM   #12
Darken
Darken 28/M
yeah i already have the new wheel with controls and cruise stick installed with the new airbag. i found someone on ebay to trade me my old airbag for the new one plus 150 bucks.
anyone know if the radio is different? i think im going to try and wire up the controls atleast.
Old 03-20-2008, 11:03 PM   #13
Darken
Darken 28/M
Old 04-06-2008, 12:26 AM   #14
tronix304
tronix304 27/M
Send a message via AIM to tronix304 Send a message via MSN to tronix304
i kno its been a while but hows this goin? any new info im def interested?????
tronix304 is offline   Reply With Quote
Old 04-06-2008, 12:31 AM   #15
jwaj2002
TOCC
jwaj2002's Avatar
jwaj2002 29/M
you could probably talk tot he toyota dealer, most of the time Toyota makes 1 main wiring harness, and just doesn't plug in whatever options the car isn't going to have
owner of the only FireBox
staypuffed
want to be original, don't remove the emblems, add some!
"One thing a Southern boy will never say is, 'I don't think duct tape will fix it.'" Keith Canfield Apollo 13 Astronaut
jwaj2002 is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
add, cion, cruise, spec, tc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
