Changing hubs or redrilling 5x114 wheels?
Which is easier, safer, cheaper? I searched, but didn't really find any good answers and I found some wheels I really want that I know aren't available in 5x100.
an adapter would be the cheapest and easiest solution but it will space out your wheels an inch or so. Hub swap is the next best option but a bit more expensive. I haven't had any experience with redrilling wheels so i can't help you out there.
Has anyone done an axle swap or had their hubs redrilled? I don't know much about this. The xB now has the right bolt pattern, is anything swappable?
...and the wheels I want do have a cap. They are 4/5x114.3.
for now getting wheels filled and re-drilled is the best option. i was quoted $75 per wheel locally. add another $20 to dismount, remount, & balance the tire.
i'd like to see if the wheel hub assembly from a Camry or other FWD 2azfe powered Toyota (new xB, rav4, etc) would fit. it would be a bolt-on swap also requiring new 5x114.3 rotors (assuming the same diameter is available).
This is the wheel hub I'm taking about
Ron Tonkin Parts (SL sponsor?) sells the front Camry hub for $90 each (item 2 in the diagram below).
A fully assembled hub assembly (with bearings and studs pressed in) can cost $150-200 each. Factor in new rotors and it becomes an expensive experiment.
So who's gonna try it? LOL
Oh it requires new brakes too? Damn, that sucks, shows what I know.
Surely there is a totaled Camry sitting in a junkyard somewhere...
$300 for drilling the wheels doesn't sound too bad.
Surely there is a totaled Camry sitting in a junkyard somewhere...$300 for drilling the wheels doesn't sound too bad.
Originally Posted by nebster
pssh, i'd so rock 5x114.3 if i could afford it. such a better selection of wheels
mrsocks
Jan 20, 2015 01:29 PM
