For those who cleared their Headlights
Old Dec 1, 2004 | 09:15 PM
MotoMan_YZ400's Avatar
Default For those who cleared their Headlights
Ok i did the normal shatter method. But i still have a sliver wedged for edge of the housing! i cant get it out.... i was going to try the oven method, but that seems messy and danagerous. How did you guys get those last few pieces out?
I need help ASAP... cuz right now, the xB is down!
Old Dec 1, 2004 | 09:40 PM
fireballfish's Avatar
Default Re: For those who cleared their Headlights
I custom bent a lng thin flathead screwdriver for just this... don't get too frustrated... mine took 45 minutes or so even with the custom SD. Just take your time, you dont want to scratch the inside of your lens.
Old Dec 1, 2004 | 09:43 PM
TheDanger's Avatar
my friend used a coat hanger to get in there and pulled it out...way we did mine was hit that piece again and it popped right out. Just dont get too mad and take your time...
Old Dec 1, 2004 | 10:57 PM
Well i did it.... I just had to use a small SD and use my hand to bop... kinda had to wiggle it out. I was surpised about how easy it really was, (now know how to do it).
Thanks for all the info guy, it eased my mind during the procedure.
Now how to install Blue LED blackling in there
Old Dec 2, 2004 | 01:43 AM
erichlf's Avatar
I did oven method. It was messy, but should have done that from the beginning. If you use the oven method you don't really need to pry up anything. This will just permanantly bend the plastic. This is what I did on my first headlight. The second one I just pulled the tabs up by hand and it worked just as well with no plastic being distorted.
Old Dec 2, 2004 | 01:49 AM
TheDanger's Avatar
no prob! pics pics...heres mine.
Old Dec 2, 2004 | 02:00 AM
Now i have a few test LEDs on the way.... gunna make it so they glow a blue color (much like Danger's) but still blink Amber (gotta keep her legal!) The cool think is, if i dont like the color blue, these are RGB (Red/Green/Blue) LEDs, so i can make them what ever color i want :D
Old Dec 2, 2004 | 03:02 AM
TheDanger's Avatar
really cool moto! Mine are just silverstar bulbs...I ordered some chrome ones that light up amber.
Old Dec 2, 2004 | 04:35 AM
rogcjms's Avatar
NM SCIONS
i wish i could clear mine but im too afraid do to it! I dont wanna scrath the inside.
Old Dec 2, 2004 | 07:25 AM
shapinoweno's Avatar
just go for it man...
I was all scared and i just went for it...i had the front end off in 25 mins.
(the tutorial helped a lot) The trick is to hit the reflector pretty much in the middel, and to hit it fairly hard.
The first one i did i dident make the reflector compleatly shater and i had a hard time geting a reaming peace out.second light was peasy
Old Dec 2, 2004 | 07:41 AM
...The first one i did i dident make the reflector compleatly shater and i had a hard time geting a reaming peace out.second light was peasy
Yeah mine broke into 2-3 pieces.... I simply held the lamp at an angle so the shards were to fall down close to the hole, just enought to get a pair of small angle cutters up in there to grab on, and just cut right through it. each peice will shatter into about another 3-4 peices. keep doing this till they simply just all fall out. NO SCRATCHES!! Well i do have one small, unnoticible dot, where one peice was too long and wouldnt fall to the hole, so i had to take a pair of long needle nose, and grab, then twist it to break. Wasnt being too careful when doing this, but it worked. Looks nice!! took a while to get the amber dust out of there (got a few small peices behind the reflector, and a small spek on the main headlamp side ) but it worked out. Really havent seen them on in the day light (had to put lamp back in and bumper back on @ 8pm by light of a LED keychain light danglin from my mouth :oops: )
Old Dec 2, 2004 | 12:43 PM
ScionXBrent's Avatar
... I did the oven method... actually a friend. Came out great.
Old Dec 2, 2004 | 03:51 PM
pileofmonkeycrap's Avatar
Read my posts about what I did when clearing my headlights. I had the same problem with a large piece of the tab beinging stuck and not able to shatter that remaining piece. I used the oven method, but didn't pry apart the entire housing. I only spread the housing apart at the end where the tab still was. Then with a thin screwdriver I was able to slide it in and just poke out the tab from underneath.
https://www.scionlife.com/forums/vie...577&highlight=
https://www.scionlife.com/forums/vie...684&highlight=
Old Dec 3, 2004 | 05:05 PM
erichlf's Avatar
Have mine blinking blue. Yes, definately illegal. Waiting to get pulled over. Have the amber sitting in the glove box.
Old Dec 3, 2004 | 08:45 PM
BrianxB's Avatar
Use the oven method. The shatter method usually yields poor results.
Old Dec 3, 2004 | 08:58 PM
use white bulbs for the signal bulbs. front turn signals can be white or amber and i personally tthink whit looks better. besides removing the reflectors your lights are allready illegal.
Old Dec 3, 2004 | 09:31 PM
VanillaRice's Avatar
Originally Posted by hotbox05
...besides removing the reflectors your lights are allready illegal.
Where did you find this information? If I clear my lights but leave amber turn signals are you saying that my lights are illegal? I can't say I'm buying this one. Show me where you found this law written.
Old Dec 3, 2004 | 09:57 PM
yep all cars need reflectors in the front and rear lighting. i am not lying but i dont have the time to look thru california vehicular code right now. ask squirrel. oh and not only is it a ca law but it is also a fed law.
Old Dec 4, 2004 | 12:23 AM
CBSIMONSEZ's Avatar
Tiss true, you need a reflective amber n the front, and a red reflector in the rear. Just for this reason was why som many people were having problems with the clear tail lights in past years. No reflective red in the rear.
Old Dec 4, 2004 | 12:27 AM
Now i dont know about Cali.... but here in Va....
According to VA State Law:
"Every turn signal used to give a signal of intention to turn a vehicle shall be so constructed and so installed as to give a signal plainly visible in clear weather and under normal traffic conditions from a distance of at least 100 feet to the rear and 100 feet to the front of the vehicle."
Just remove all your singals.... just use your hands
"Signals required by § 46.2-848 shall be given by means of the hand and arm or by some mechanical or electrical device... ...Whenever the signal is given by means of the hand and arm, the driver shall indicate his intention to start, stop, turn, or partly turn by extending the hand and arm beyond the left side of the vehicle"
Source: Va DMV (http://leg1.state.va.us/cgi-bin/legp...+cod+46.2-1039)[/b]
