Radio/Stereo fuse location
Old Jun 17, 2008 | 06:24 PM
xDrug's Avatar
Default Radio/Stereo fuse location
Hi guys ! I've looked in the manual, but couldn't find it. The question: which fuse handles the stereo HU and where is it located ? How do you remove it ?
Thank you !
Old Jun 17, 2008 | 07:02 PM
TrebleStauter's Avatar
It isnt the easiest thing to get to. Although, it is in the manual.
Just behind the storage drawer to the left of the steering wheel. You will have to get your head under there to see it. There is a small plastic cover that you have to pull off.
The cover has a diagram on the back of each fuse and its purpose.
Old Jun 17, 2008 | 07:32 PM
xDrug's Avatar
Thank you, sir !
Old Jun 18, 2008 | 02:55 AM
DXNOICS's Avatar
Default fuse for Radio
It is actually located in the fuse block under the hood next to the battery. It is the only 15 amp (red) in the block. Also controls the map and dome lights.
Good luck
Old Jun 18, 2008 | 04:01 AM
xDrug's Avatar
OK, guys. Now I'm confused. THIS fuse on THIS car can only be in ONE location. So one of you is full of it So which one of you is talking from personal experience ? DXNOICS - the one you've mentioned is #19 in the manual and it's said to control interior light,personal lights,luggage compartment light. No mentioning of stereo ...
Have you worked with it, you're sure it's the one ?
Old Jun 18, 2008 | 11:19 AM
Sorry, let me check when I get down to my car. I was in that area this weekend and I guess just assumed the stereo fuse would be there in the interior rather then the engine compartment.
I will check and reply later today.
Old Jun 18, 2008 | 12:27 PM
It turns out that I am the one who is full of "it". The lighter and accessory fuses are on the interior, as well as the doors and signals. However there are no fuses labeled stereo.
I apologize for leading you down a dark path to nowhere.
Out of curiousity, why are you trying to find this? I would be surprised to hear that you need to replace the fuse.
Old Jun 18, 2008 | 11:17 PM
DXNOICS's Avatar
I had a personal experience with it last weekend when I plugged in the clock connector to the back of the radio!
I too hunted for a while until I found it. It is not in the manuals.
Old Jun 19, 2008 | 05:08 AM
xDrug's Avatar
OK. One more time - thank you very much to both of you ! I really appreciate your help and now I'll be confident to go mess with my car this weekend ))
What I'm trying to do is to see if I can override the "safety" feature on my new Scion Nav system. I've got an improved map CD that works on some other Toyotas. I'll need to remove and re-insert that fuse to reset the HU and re-instal the map disc. Then it should let me use all the nav features while moving. I hope it works.
Cheers !
Old Jun 19, 2008 | 11:12 AM
Awesome. I hope that works for you. Good luck!
Old Jun 22, 2008 | 06:26 AM
tmrepp's Avatar
It's above your feet below the steering wheel. The fuse that's under the hood is a 15amp accessory fuse. The fuse that powers your radio is under there. I think it's a brown 20amp fuse, I had to replace mine when I fried it. Just read the cover and it's right there. If you can't figure it out, I'll let you know which one I replaced (by the name on the cover).
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
KILLER
Mar 29, 2015 05:32 PM
GetSlideways
Scion xD Drivetrain & Power
Mar 16, 2015 11:30 PM
