OEM seat lever
Old Jun 28, 2008 | 08:39 PM
kuo34's Avatar
Default OEM seat lever
The lever at the top of my driver's seat has stopped working. I'm guessing a clip or screw has come loose from a cable between the lever and the reclining lever at the bottom. It has no resistance lifting up like the passenger's seat lever does. Has anyone ever fixed this problem or does anyone know how to take the seat apart enough to fix it?
Old Jun 28, 2008 | 11:04 PM
SquallLHeart's Avatar
at the top of my head.. i can't tell ya right now.. i'll take a lookie, but make sure nothing under or around the seat is causing it to jam up.
Old May 26, 2013 | 11:59 PM
Killakb's Avatar
<br />
<br />
I had the same thing just happen to me so if you figure it out fill me in the lever does not lock it just snaps back down after I lift it. No connection!! Sucks!
Old May 31, 2018 | 01:16 PM
rideevol's Avatar
The reclining remote control is not detailed in the repair manual. Some day I may summon the courage to remove the upper seat hog clips and fold up the upper seat back fabric. Most likely a broken/damaged end at the upper remote lever. Use care if you attempt access as the negative battery terminal should be removed and key OFF, wait at least 90 seconds, or else SRS(air bag) could go off if you disturb seat air bag connector.
They say hog clips are not reusable, probably true so we will also need new fabric clips handy for reassemble.
bluemex
Jun 16, 2015 03:22 AM
xa007xa
Mar 29, 2015 10:37 PM
carid
Jan 22, 2015 12:49 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
randode
127
Aug 19, 2004 03:26 AM
