Question
Hey all,
I am not sure if this question has been asked or if this is the right place to post it and sorry I didn't look into the owner's manual for this, when I started the ignition on the car the word "maintenance required" pops up 4-5 times then goes away while I drive. Just wondering should I be worry about it? Has anybody have this problem before on the tC? By the way I had my oil changed last month at the dealership
Let me know
Thanks
Let me know
Thanks
I usually got that light when I think it was due for a mileage checkup, in the manual it'll say. It usually gets reset when you get an oil change but one time they forgot and it kept going off, so i called them and they gave me instructions to stop it.
how do i clear the 'maintenance required'/oil change light using the trip meter button?
if at the time you changed your oil, you or the person changing your oil did not reset the 'maintanence reqiured'/oil change light or if you would just rather turn it off instead of setting the interval (aka- the lazy way to turn off that annoying light), follow these steps:
step 1
turn the key to the 'on' position.
step 2
reset both trip meters to zero. you can reset the trip meters to zero by selecting trip a or trip b and holding in the trip meter button for five (5) seconds.
step 3
after both trip meters are reset, select any trip meter and hold in the trip meter button and start the car.
step 4
continue holding the trip meter button until the "maintenance required' light disappears.
should work...the site = http://home.cfl.rr.com/icdedppl/faq.html it has a few godd lil tidbits of info
step 1
step 2
step 3
step 4
its just a reminder light. you dont have to follow it. i reset it a different way from the above steps...
with the engine turned off
1. press and hold the trip meter button
2. turn ignition 2 clicks but dont start engine
3. continue holding trip meter button and wait for 'maint req' light to stop flashing
4. done
fyi this also works for honda's
4. done
Originally Posted by Kanchi
Has it been doing it since then?
Thanks all for replying back. I will try that out and let you guys know if that works
As Infamous and Davie said, it is just a reminder light. It is tied to the odometer, not an engine indicator. It will start blinking like that once you hit 4500 miles since it was last set, and will stay on once you hit 5000 miles. It is supposed to be reset at the time of an oil change, but it gets missed quite often.
The light is not telling you there is something wrong. It is just to remind you of the maintenance intervals. No worries!
Just wanted to update you guys and let you know that I tried those two things suggested by Infamous425 and Davie06TC and the light still shows up, but like some of you said don't worry about it so I won't. But thanks again guys for your help
There are directions in your owners manual. It is page 106 of the 2009 Scion tC owners manual. Here are the directions:
Turn the engine switch to the "OFF" position with the odometer reading shown.
Turn the engine switch to the "ON" position while holding down the trip meter reset ****.
Hold down the **** for at least 5 seconds. the odometer indicates "000000" and the light goes off.
This should work. Good luck.
bootlgr
Jan 26, 2016 01:22 AM
