Camera help with nightshots (56k warning)
Old Aug 2, 2008 | 10:25 PM
Scionarra's Avatar
Default Camera help with nightshots (56k warning)
first of, before you go ahead on knock on anything, i wanna say that i'm not claiming my friend is a super hot magazine model... personally i think that she's cute and looks good on camera...
so lets just keep the "she doesnt belong on that car" comments to ourselves... if you like the shots, compliment, if you dont, leave it off the thread...
what i do need help with is how to set the camera to make the most of my shots... i will be taking shots at night... you can see the color of my car on the pics and i want to highlight it as much as possible... i will be running a Nikon D40x... should i use a tripod or should i not?
let me know... so far, these are some shots that i took on my point and shoot... and i want these type of shots on an SLR... i need some tips
Old Aug 2, 2008 | 11:15 PM
testa422's Avatar
bro...your car look seriously sick and if anybody doesnt find her sexy, they need some stronger glasses!!
Old Aug 2, 2008 | 11:19 PM
nebster's Avatar
first advice, don't ever use a flash at night, use external light sources. 2nd, get a GOOD tripod, i dunno if its the camera or just the lack of tripod but the pictures aren't very crisp.
overall good job
Old Aug 2, 2008 | 11:20 PM
indyTC's Avatar
nice..love the vizage =)
Old Aug 2, 2008 | 11:35 PM
Scionarra's Avatar
overall good job
yeah i think its the camera... like i said, i used a point and shoot...
i have a tripod that i can use but as far as the iso goes, where should i set it at?
Old Aug 2, 2008 | 11:37 PM
Scionarra's Avatar
also you mentioned to use external light sources... what you mean? examples?
Old Aug 2, 2008 | 11:43 PM
nebster's Avatar
like flood lamps would work but most likely unneeded for this application, iso depends on how much light you have... the higher the iso the lighter the picture but the more grainy it will be. if you have a good tripod you can set it around 200-300 and then increase the exposure time.
Old Aug 2, 2008 | 11:47 PM
BlizZard's Avatar
she's cute
Old Aug 2, 2008 | 11:54 PM
Scionarra's Avatar
there were certainly some angles in which i felt like i needed more lighting bc of the way the shadows appeared so i was thinking of flood lamps to help but wouldnt i get reflection on my car from it?
if i do use floods, most come with bulbs that omit a yellowish hue... any other suggestions?
Old Aug 3, 2008 | 12:52 AM
Dakine's Avatar
Concept in Motion Crew
r u using a point and shoot camera? pics are horrible. but yes, u have a nice model and good lookin friend. i say retake your photos and use a tripod, SLR and practice
Old Aug 3, 2008 | 01:00 AM
Scionarra's Avatar
At these pics, I used a point and shoot cam to show what kind of pics I want but I WILL be using a SLR. So for sure, I will be retaking shots.
Old Aug 3, 2008 | 01:09 AM
trentonm's Avatar
lower iso, and no need for flood lamps what so ever. There is enough "natural" lighting. I use natural loosely, there are plenty of lights around you, no need to add anymore than whats already there. You will need a VERY steady model, that can not move for up to a minute. I think a minute exposure from what I can tell will be way to long, but 15-30 second exposure should work just fine.
a point and shoot digi cam works just fine. just need to play with it enough to figure out how to work it for your setting.
Old Aug 3, 2008 | 01:25 AM
CSOCSO's Avatar
she looks good but tell her not to to this with her arms:
crooked arm... cant stand it :D:D:D
ADVICE:
you need a tripod for night shoots
dont use flash.. NEVER EVER!
lowest ISO
usually i put the exposure to 1-6sec.. anything above that i use it only in pitch black
let me show you something:
exp was only 0,6 sec on both pics
Old Aug 3, 2008 | 01:45 AM
tC2_thumper's Avatar
HOT but yah pretty much same advice as everyone else. ISO, shutter speed, and aperture. once you get the d40x just take a pic, change something, look, and repeat until you get the desired effect. sometimes takes a long time to set up right, well for me but im very novice. and a tripod is a MUST.
Old Aug 3, 2008 | 03:14 AM
Viace's Avatar
She is pretty cute, your car looks good also
Old Aug 3, 2008 | 03:31 AM
foose801's Avatar
Utah Scions
csocso, great night shots and use of natural light sources man.... love it
Old Aug 3, 2008 | 04:05 AM
Big_Bird's Avatar
I dunno, but damn she's cute
Old Aug 6, 2008 | 05:27 PM
Scionarra's Avatar
ok, i went ahead and gone through part 2 of my 3 part series...
i took some shots last night... i am very happy with the shots... some came out blurry bc my model moved a bit but i think most of it turned out great for my first time with an slr...
i had the iso set at 100 and found that 1.3 secs of exp was perfect for her bc anything longer just made her look like casper
here's some shots, more to come later
Old Aug 6, 2008 | 05:35 PM
CarbonXe's Avatar
First, get a tripod.
Second, the D40 has an automatic meter to show you if the shot is over exposed or not. Set the aperture to the highest setting possible (3.5 if you're using the standard 18-55mm lens). Set the ISO to the lowest setting, no need for the ISO to compensate for light if you're using a tripod, plus ISO = grainy pictures. From there, just adjust your shutter speed and you'll have sharp pictures every time. Only problem with low lighting and slow shots, is that it's difficult to get sharp shots of people, since it's hard to stay very still (usually for shots of 1 second exposures or longer). From the looks of the area, it's lit way more than enough to worry about that.
Just keep playing with the camera and you'll eventually learn what all the settings do. I got my D40 about 4 months ago and I only shoot with manual mode now.
And one more thing, take lots of shots. Take like 5 pictures for every shot you're trying to take, then when you finish, just go thru and pick the best one.
Old Aug 6, 2008 | 05:49 PM
Scionarra's Avatar
I had a tripod, it just got windy over at lake michigan... (they do call us the windy city)
also, i wanted to take pics of my car in front of one museum but the lights they had were just super yellow... is there any way i could set the camera to eliminate some of that yellow hue?
