when they dyno a cai like k&n, and aem??
you guys know how say they yeild an 8 hp increase, but doesnt the cai really help the most when driving at high speeds with all the cold air flowing into it , cause when its on the dyno no air is being forced into the cone
they should have a huge fan blowing air over the radiator / front end. (otherwise it could over heat...)
the hood should also be opened, to let heat rise away from the motor...
That's why a dragstrip is the only real place to see if there is improvement or not. Of course, it requires a very consistent driver... one reason why the best e.t. bracket racers never have to look for work...
Yup, takes all day if you have the track to yourself. All weekend if you don't. But its a tried and true "old school" method that these newfangled dyno's just can't quite reproduce.
Oops, I'm showing my age again...
)))The idea is that the air aroudn the fender is cold as opposed to air from the engine bay or behind the radioator........
The fans on the dyno are supposed to compensate for natural air flow through the radiotor so the engine does not overheat, nothing else........
I remember a guy who posted a month or so ago...did a CAI, header, and something else...basically spent at least $800-$1200 or so and ended up with about 8hp extra.
I guess stating that you will get 8hp with just a CAI is a little optimistic.
There's not much difference between a CAI and a short ram period. A good intake should be a supporting modification, not a modification by itself. As long as it filters the air and is as unrestrictive as possible, it's serving its purpose. It will allow everything else to perform at its peak. If you're putting on an aftermarket intake system just for the few hp you'll get out of it, I hate to say it, but your car is probably not very fast.
