Register Forgot Password?
Reply
Old 08-11-2008, 06:40 PM   #1
lltysonll
lltysonll's Avatar
lltysonll 28/M
Send a message via AIM to lltysonll
Default Steering wheel vibration 70+ mph
hey SL. I'm getting vibration in my steering wheel @ 70+mph. I have replaced my tires an have about 10k on the new ones. I got alignment and balace on the old tires and brought it to a chassis ams suspension shop that only specializes in suspension & alignments but still getting shakes. so I went ahead and bought new tires bc they said I need new ones which I did. Hoping it would solve the problem but it didn't. btw on stock rims. You think I could have a bent rim? And the vibration comming from the front end. Thank for your help guys.
lltysonll is offline   Reply With Quote
Old 08-11-2008, 09:57 PM   #2
Spicy_McHaggiz
Spicy_McHaggiz's Avatar
Spicy_McHaggiz 26/M
Have you hit anything with the rims or hit a large pot hole?
Did they completely tighten the wheels?
He's such a dick that his car even wanted out so it drowned itself.
TROOOOOF. My "Lesbaru" is slow though, only 13's in the 1/4 fml. <That's SUPER PERFORMANCE (Right Hayfail?)
Spicy_McHaggiz is offline   Reply With Quote
Old 08-11-2008, 10:08 PM   #3
weeloTC
weeloTC's Avatar
weeloTC 32/M
Send a message via Yahoo to weeloTC
rotate the tires, if it vib in the rear, then its a wheel, if not you might have a bad hub assembly, wrap brake rotor, loose front end part, ect, ect, try having a different shop balance the wheels, sometimes you might get a shop that has some new kid working and they dont understand that some wheels need to be static balance to one side, or maybe a weigh come off down the road if they didnt put it on right, you just need to let a shop look at it, its not really something that can be fixed over a forum
SO LET ME GET THIS STRAIGHT, YOUR HONDA HAS 1.6 LITERS, WHEREAS MY BOTTLE OF MOUNTAIN DEW HAS 2....
Pic/Build Tread
weeloTC is offline   Reply With Quote
Old 08-11-2008, 10:24 PM   #4
dropzone
dropzone's Avatar
dropzone 30/M
When did you notice the tire vibration? If it was after you had the tires swapped out it could be a broken tire pressure sensor. It happened to me when I got my tire repaired for a nail at Sears. It likely happened when the tire got put back on and the person wasn't paying attention to details. When I would go above 70 MPH my steering wheel would vibrate and wouldn't stop until I slowed down to under 60 MPH. I took it back to Sears and they checked the suspension and it checked ok. Then the tire that was repaired was checked on the balance machine at a slow speed to listen for anything loose inside the tire and was broken down. Next thing I'm being handed my tire pressure sensor and the valve stem is still on the wheel . Since the sensor was broken during their repair of the tire the covered buying the new one and put it on. But here's the kicker, the car has to be taken to the dealer so the ECU recognizes the new sensor. I got hit with an $80 bill for them to break down the tire again to get the serial off the sensor and to reprogram the ECU. I was was not happy about that and made a trip back to sears after that to get reimbursed but only got half back though(when I went it was like a week later and talked to a different manager and tried to tell me different about how the TPMS system works, lol), I also only had 2 hrs of sleep so I lost out some money. So now your informed, of it is a broken sensor have them take the car to the dealer to make sure they take all charges.
Sometimes to win an argument, means losing the bed.
Upgrades: Agency Power Exhaust
RS 5.0 tC Roll Call
NEVER FORGET ROSA PARKS
dropzone is offline   Reply With Quote
Old 08-11-2008, 10:48 PM   #5
lltysonll
lltysonll's Avatar
lltysonll 28/M
with my old tires I had them balanced and aligned at numerous shops. Now when I changed my suspension the ride was smooth. Later on down the line I started getting vibrations only in 80mph range. It's not happening when the brakes are applied. I will rotate the tires this weekend. If I rember correctly I do recall rotating with the old tires on and the vibration was in the back as well as front. as for the Hub asslembly never told the mechanic to directly inspect that. But I shall next time. As for as pot holes yeah hit a ton of them. New Orleans well Louisiana has the worst roads ever. So I'm leaning toward the culprit being a bent rim or like you said the hub asseembly.
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
80, end, front, hr, miles, nail, scion, steering, stirring, tc, tire, vibrates, vibration, wheel, xa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising - Privacy Statement - Terms of Service - Jobs
vBulletin® v3.8.7, Copyright ©2000-2014, vBulletin Solutions, Inc.
