RESOLVED: Steering Wheel Wobble, Low Speed, Stock Wheels - xB
Old Aug 19, 2008 | 03:13 PM
majukutaj's Avatar
Default RESOLVED: Steering Wheel Wobble, Low Speed, Stock Wheels - xB
I'm experiencing a pretty severe wobble in the steering wheel of my xB; can anyone help me out?
- The wobble is worst at around 25-35 mph
- The wobble is present whether I'm braking or not
- It's much, much less intense at highway speeds, often unnoticeable
- There's no noticeable drift or pull
- I haven't hit anything
- I haven't had any bad bumps related to potholes / speed bumps
- I'm still using the stock wheels
- I've checked the tire pressure
- I've had the tires / wheels visually inspected and balanced
My understanding is that being out-of-balance typically causes shaking at high speed, and radial wobble typically causes shaking at low speed, and that alignment is usually associated with drift / pull.
I assumed that any belt problems would be noticeable from looking at the outside of the tire, so I didn't ask the technician (GoodYear Svc Ctr) to actually remove the tires looking for defects.
Since it still wobbles, I know that I'm wrong, but I can't figure out what I wrong about. I'm hoping somebody will tell me. :D
--UPDATE--
Metro273 was right on the money; the tire's damage couldn't be seen from the outside. I had it replaced, and everything's back to normal.
Thanks guys
Old Aug 19, 2008 | 09:50 PM
hwybox's Avatar
I had this problem in the winter with packed snow on the inner wheel. Do you maybe have mud or a lot of dirt inside ur rim? clean the inside real good just a thought.
Old Aug 19, 2008 | 11:49 PM
Metro273's Avatar
I had this EXACT problem with a Maxima at work. The customers right, front tire was bad. It had a separated belt, causing the inner part of the tire to be lower than the outside, causing a wobble. It started like at 10-15 mph.
Your tech needs to put your car up in the air and have someone else give the car gas, while in drive of course, and look at the front tires closely!!! One is bad!!!
Old Aug 20, 2008 | 02:49 AM
DarkSide_xB's Avatar
ok i have this problem at high speeds only bewteend 55 and 80. but it comes and goes. it isnt constant. and im running 18's. i have to get the rims and tires checked asap cause it is starting to get really annoying.
Old Aug 20, 2008 | 03:04 AM
majukutaj's Avatar
@hwybox : No mud or anything; I remember having that problem with another vehicle though... took me forever to figure out what was going wrong.
@DarkSide_xB : I searched the forums like crazy before I started my own topic, since nobody had low-speed wobble on stockies, but I saw a lot of posts about wobble on aftermarket wheels at highway speeds. I seem to remember a lot of people having luck with hub centric rings... I'm a stock guy, so I don't really know what they are though
@Metro273 : Thanks! That's what I was afraid of, since I literally replaced a rear tire last week (this wobbling problem started happening before I got the new tire). I guess all the tires are just hitting their expiration date at once... I was hoping I'd get away with something cheap, but I'd rather be safe and broke than have a blowout or something.
Thanks for the help everybody.
Old Aug 20, 2008 | 09:48 PM
i actually dont have or need hubcentric rings on my wheels amazingly, i think they are just out of balance.
Old Aug 21, 2008 | 12:14 AM
Metro273's Avatar
Hey Majukutaj, no problem. Glad it got fixed. I like to use my technician skills and help others on here with any car problems they might have...
Old Aug 22, 2008 | 03:46 AM
bB2NER's Avatar
Music City Scions
Yep Metro273 Rocks!
rbusacco
Aug 6, 2009 01:46 AM
modified785
Scion tC 1G Wheel & Tire
20
Sep 17, 2008 11:33 PM
GreenEnvy06
19
Nov 4, 2007 11:17 AM
GreenEnvy06
Oct 14, 2007 09:31 PM
sensez
9
Jun 7, 2006 05:33 PM
