JDM Parts
Old Jan 16, 2004 | 07:20 PM
Kendo's Avatar
Default JDM Parts
Here are some images of the JDM mirror covers with LED blinkers with the "rain clear" blue tinted glass as well as the brushed aluminum "bB" rear view mirror cover and "bB" stainless door sills.
Old Jan 16, 2004 | 07:27 PM
TheRedBox's Avatar
Nice stuff. I wanted those mirrors.
Old Jan 16, 2004 | 07:30 PM
Kendo's Avatar
Default Blue Glass Mirrors
Fitment on the passenger side was perfect. The driver side however needed to be modified. The back side of the JDM glass on the driver side mirror doesn't match up with the US Spec mirror for some reason so some tabs had to be clipped off in order to be able to adjust the mirror at it's full range.
Old Jan 16, 2004 | 07:46 PM
XBBOY's Avatar
Those look nice Kendo...I believe Crystal from TSW has those side mirror covers and they look awesome..."I needz me dem covers". Your car is look great nice job.
Old Jan 16, 2004 | 08:07 PM
randode's Avatar
Wagonistas
they are getting painted right now :D
Old Jan 16, 2004 | 08:15 PM
Inazuma's Avatar
hehe kendo...
I like the blue glass pic with my xB in the background..
I did not know you took that pic when u had my camera..Nice Pic..hehe
Old Jan 16, 2004 | 08:55 PM
FLXB's Avatar
where to buy some of these jdm parts ---- here from the sl site or are there some other importers i was thinking of the ts mirrors but i havent made up my mind just yet as im awaiting delivery of my xb they look great but is it just black plastic or can you get them painted ???
thanks
chad
Old Jan 16, 2004 | 09:18 PM
Kendo's Avatar
Default JDM Parts
I picked up the JDM badges, door sills, rear mirror cover, blue glass mirrors, and the blinker side mirrors from Steve at Carson Toyota/Scion. I ordered the mirrors prepainted in black to match my xB's color. They come unpainted, or you can order them prepainted.
Old Jan 16, 2004 | 09:29 PM
Mr_scion's Avatar
N.G.S.O.
you can get that here
http://newscionparts.com/
Old Jan 16, 2004 | 11:54 PM
its_ikon's Avatar
those products look sweet.
Old Jan 17, 2004 | 04:11 AM
FLXB's Avatar
Default jdm parts
i found them on another post ill have to keep that in mind thanks i do like some of the parts i did notice that the sig morrors look different then the ones posted on the photo above
Old Jan 17, 2004 | 08:20 AM
HotBox's Avatar
Default Re: JDM Parts
damn going jdm huh niceee
i really like this pic its very cool
Old Jan 17, 2004 | 12:40 PM
Munch's Avatar
I'm getting those mirrors :D
Old Jan 19, 2004 | 08:30 PM
Kendo's Avatar
Default Blilnker Mirror Install
The install is pretty straightforward, but the instructions were in Japanese.
Basically, it involved:
1. Disconnect the negative terminal of the battery
2. Remove side mirror glass (Mask off the bottom portion of the mirror housing and then pry the bottom part of the mirror off. It snaps in in two spots on the bottom. There is also some white adhesive goo on the back that you will have to deal with)
3. Remove Door Panel (have your windows rolled down as well)
4. Disconnect the plug for the mirror motors
5. Pull the black triangular cover off of the inner side of the mirror
6. Remove the 3 nuts holding the mirror on and remove the mirror from the car.
7. Remove the 3 torx screws on the bottom of the mirror and remove the 1 philips head screw holding the rubber piece that seals the mirror.
8. Drill a hole in the factory mirror housing just above the mirror motor. The instructions called for a 8mm hole. I think I did mine only at 7/32 though. I started with a small pilot hole and made it just large enough to get the wiring through.
9. Attach the LED portion to the inner side of the mirrors.
10. Feed the wiring from the LED unit through the drilled hole and run it along the same route as the factory wiring for the mirror motor.
11. Attach the blinker mirror cover to the factory mirror housing. (Make sure the factory mirror housing is clean before attaching the JDM cover)
12. Reattach the mirror glass, 1 philips head screw holding the rubber piece that seals the mirror, and the 3 torx screws. Then reattach the mirror to the car.
13. Slide the rubber protective tubing over the wires and attach the supplied connector to these same wires.
14. Pop the side marker out of the fender. Connect the supplied T-connector wire harnass to the wiring for the side marker.
15. Feed the long end of the T-connector wire harnass through the back side of the fender and UNDERNEATH the weather strip of the front door. Use the supplied foam tape to secure the wire at the point BENEATH the weather strip.
16. Connect the end of the T-connector wire harnass to the connector attached to the LED blinker mirror cover.
17. Clean up the extra wiring length using supplied zip ties and secure them down neatly.
18. Put the door panel back on and reconnect the battery and you're done.
19. Install procedure is the same for both sides.
Old Jan 19, 2004 | 10:44 PM
Inazuma's Avatar
HOTBOX--
you probably like my xB in the background huh?
Old Jan 19, 2004 | 11:10 PM
Kendo's Avatar
Default lol
Nah dude, it's the blue tinted mirrors not your ride... lol =Þ
Old Jan 19, 2004 | 11:26 PM
HotBox's Avatar
its not ur ride or the blue tinted mirror its the scenery jk
Old Jan 20, 2004 | 12:33 AM
Inazuma's Avatar
just kiddin
Old Jun 25, 2004 | 06:58 PM
philip's Avatar
-will the jdm rear spoiler fit the xb with no modification?i noticed the jdm spoiler only sells for $172 while the non jdm is $242.
Old Jun 25, 2004 | 07:33 PM
TheScionicMan's Avatar
I like the lights on the top - That's hella JDM...
