you sure its brakes? and not warn tires, brakes don't care what direction you're moving, now my bald ___ tires screeched when i turned even at low speeds but not my brakes
Ben aka "GUB" aka "Nebster"
TEAM SOLO - www.teamsolo.net
DO NOT PM ME. I WILL NOT RETURN YOUR PM AND WILL TELL YOU TO F OFF.
either rotors warped and no pads.. uneven wear or something.. you probably need to get under the car and examine the brake pads.. if it's metal on metal.. switch them out asap.
__________________ EDRII '07 - 1st Place tie - Best mildly modded tc's The Premiere '09 - 3rd Place - Best street tC 2010 Unlock the tC - 1st place - Best Stanced tC BlkTC's Official Picture Thread http://www.scionlife.com/forums/view...696&highlight=
yeah check the rotors if its warped or if the brakes are worn.. you might also check the wheel bearing, a bad one can cause the calipers to rub with rotors and score it really bad but the noise more of a grinding, metal rubbing noise.. if its a screeching noise, i bet its the tires
My car is an alcoholic
WTB: scion tc cam buckets #14 or anything aroung 12-16.. pm me if you have
I have the squeal from my brakes, but only some of the time when im braking (probably 75% of the time). Its annoying but I haven't been able to get my car on a lift to take a look.
maybe you have hawk pads.. hps plus. ceramic pads will eat up your rotors.. i don't know what you have.. but an estimated cost could be quite expensive.. new front rotors and new pads.. maybe 270 give or take..
orrr, you can pm me on a hook up for all four rotors and brake pads for less than that...
