INSTALLED: OneTonGarage spacer shims on xA RS
Old Dec 19, 2004 | 11:30 PM
Epitrochoid's Avatar
Default INSTALLED: OneTonGarage spacer shims on xA RS
I got my spacer shims from Van at OneTonGarage yesterday...
The shims are VERY nicely finished and great quality. All needed parts are included.
The intall was easy and straight forward. Van's instructions are good but one WARNING: watch the ABS plug on the hub. I hit mine and broke a piece off. I fixed it with CA glue and good 'ol duct tape. :D
These are 5mm shims so the final result is subtle. When I finished the first one and looked at the other side the difference was obvious. Basically the car looks how it should have from the factory. Instead of having a sunken in look on the rear well it looks more full. I'm considering adding the 5mm wheel spacers, which work with the shims, and go for a more aggressive stance.
Take a look at the pic carefully and you will see the difference. I was careful to take both pics from the same angle to show the true difference. The second pic is just to show my RS with TRD springs and the shims.
Old Dec 20, 2004 | 04:17 AM
DJ_X_Trodinaire's Avatar
looks alot better!
Old Dec 20, 2004 | 05:05 AM
Welcome to spacer club, scionvan from onetongarage is a cool guy. He stops by the scion central whenever he can. I got them too and they work great. :D Congrats on the cool mod!
Old Dec 20, 2004 | 01:51 PM
Thanks!
I think another 5mm will be perfect. I like the idea of using the shims with a wheel spacer better than using a 10mm wheel spacer alone.
Old Dec 20, 2004 | 04:46 PM
A lot of people are doing that, just make sure that when you lower it that the extra spacer doen't make your tires rub when you go over bumps.
Old Dec 20, 2004 | 04:48 PM
Munch's Avatar
Sweet Much better now
Old Dec 20, 2004 | 05:33 PM
The TRD springs I have are a more modest drop. I can see that rubbing would be a problem with more aggressive springs.
Old Dec 20, 2004 | 06:01 PM
hahajoey's Avatar
see! van at onetongarage is the man!
im glad ur ride is flusher now! it looks a LOT better!
goodluck
Old Dec 20, 2004 | 07:33 PM
the TRD springs? Oh yeah, you won't have to worry about any rubbing at all. Perfect ride on those springs too. :D
Old Dec 21, 2004 | 04:30 PM
I just ordered the wheel spaces from Van. :D look for updated pics towards the end of the week, hopefully.
ruzzzell
Oct 11, 2015 04:18 PM
terrye
Sep 26, 2015 12:24 AM
axB
Sep 18, 2015 06:11 AM
umnitza
Sep 1, 2015 08:06 PM
reniculous1
Aug 14, 2015 03:16 PM
