Can you guys help me with a system?
Old Dec 22, 2004 | 02:39 PM
myXAisSeXaY's Avatar
Default Can you guys help me with a system?
hello...
sorry i ask way too many questions, but im still a beginner.
My xa has the 6 cd changer with speakers, factory installed and all.
i was wondering, i want to add onto that with subs n an amp witht he whole cool looking box thing.
but i need a guide!
can u guys give me any info on the basics i need and maybe some sites i can look at?
thanks u so much
Old Dec 22, 2004 | 02:53 PM
matt_a's Avatar
Default Re: Can you guys help me with a system?
Originally Posted by myXAisSeXaY
hello...
but i need a guide!
thanks u so much
Oh man....you have sooooooo many options when it comes to sound systems. The first thing you should figure out is if you want to sacrifice any of the already-small cargo space the xA has. Adding an enclosure with big subs and amps might make the car rock out, but you will have zero storage space. If your not worried about having a system that will blow the windows out, you may want to consider just adding the Bazooka sub tube for more punch. It doesn't take up all your space, plus it's easily removed if need be. Stop by a local custom stereo shop to learn about some options.
Old Dec 22, 2004 | 03:02 PM
could i use any sub? like instead of buying the bazooka sub tube or whatever...is it possible to buy any smaller sub and place it back there n it will give the system more punch? cuz i went to a local shop n they told me if i put a sub in then i need an amp...so i dunno, im gonna have the shop install it all, but i wanna make sure i get all the right pieces, and get a better system in the cheapest way i can.
thanks for responding, i appreciate it
Old Dec 22, 2004 | 03:07 PM
Old Dec 22, 2004 | 03:20 PM
matt_a's Avatar
No problem. The Bazooka sub tube has it's own amp built-in (I'm pretty sure). Obviously it's not going to give you the same performance as a seperate amp/sub. But, like I said before, the increased performance comes at a cost...room and money. You just need to decide for yourself which way suits you best. Personally, I think the stock system sounds pretty darned good once you adjust the settings a little.
Old Dec 22, 2004 | 03:23 PM
my buddy djctwatt is glass'in his own boxx that will sit in the cavity above the spare tire. and it will sit flush to the cargo lid.(not sure if that made as much sense as in my head but anyways) yeah . lots of options. all about airspace , brand , power you are planning to push , custom enclosures and the nine. sooo many options. once u give a lil bit better description of what u want outta the system people will be able to help. that or move it to ice.
Old Dec 22, 2004 | 03:24 PM
grnxb's Avatar
you may want to hit www.the12volt.com and www.sounddomain.com.
They can give advice based on 1.) your budget
2.) what kind of music you listen to
3.)your preference: Sound Quality VS. Loudness
4.) space available
Also check out www.bcae1.com Offers good explanations of how things work, how to wire system, etc.
All of those sites will also offer info on how to install your own system, if you choose to do that.
Good Luck.!
Old Dec 22, 2004 | 03:59 PM
i found a sub tube i like from bazooka...if its a 100wat sub, and i have 2 of them, how do i figure how big of an amp i need?
just for future reference.
and thanks to everybody who dropped help.
Old Dec 22, 2004 | 09:41 PM
arave's Avatar
may i suggest .. if you dont want to waste the trunk space... just find a really good mid speaker in moderately priced.... it will give you some punch... cause when u think of it xa dont have a big spae to cram with all those equipment...
next option if u really want some sub... u only need a 10 inch sub and an amp ... that will do.... buy a 2 channel amps... ! and kicker sub... the square shaped ones... its one of the thinnest sub u can cram into the side space of the trunks... so u still pretty much keep that trunk space...
evolving_machine
Oct 21, 2023 01:16 PM
carid
Feb 9, 2015 01:49 PM
NewBox06
Feb 3, 2015 04:02 AM
DjFrOsT
Dec 13, 2003 04:18 AM
DjFrOsT
Nov 6, 2003 04:54 AM
