Shim Kits
Old Dec 22, 2004 | 06:31 PM
axiom's Avatar
Default Shim Kits
How do shim kits for the rear tires effect handling, do they improve it or is it only for looks?
Old Dec 22, 2004 | 06:34 PM
hahajoey's Avatar
wider is better right? im not 100% sure, but if the wheels are spread MORE apart, i think u'll just have better traction.. rear traction is very important even in FWD cars.
i dont see a down side to it.
u get to have less sunken wheels, u'll have better traction!
what else can u ask for!?
Old Dec 22, 2004 | 07:01 PM
axiom's Avatar
I guess I just wanted to know if it would hurt or hinder the performance.
Old Dec 22, 2004 | 08:40 PM
Epitrochoid's Avatar
The wider track improves handling. I've noticed that the car feels a bit more stable around sharp turns with the shims installed. I have the 5mm wheel spacers on order too and that should improve it even more (and look better too!).
Old Dec 22, 2004 | 10:12 PM
axiom's Avatar
What size do you have now and do you add to that or replace it? Sorry for my ignorance.
Old Dec 22, 2004 | 11:32 PM
Right now I have 5mm hub shims and I will add the 5mm wheel spacers when they arrive for a total of 10mm out from stock. I like doing it this way better than using a 10mm wheel spacer.
Did you see my post here...? https://www.scionlife.com/forums/viewtopic.php?t=39123[/url]
Old Dec 23, 2004 | 04:51 PM
axiom's Avatar
I some how missed that post, Last question. Why do it 5mm and 5mm? Would it hurt to do just 10mm hub spacer?
Old Dec 23, 2004 | 05:02 PM
squirrel's Avatar
I wider track up front as compared to rear improves handling and steering response.
Most "street" cars have this designed OEM, but because of aesthetics (appearance), most will add spacers to the rear tires to "flush out" the rear tires. This is accomplished so that the vehicle's tires do not appear to be inwardly tucked and move them outward so they are flush w/ the fender lip.
This can also be accomplished be running staggered fitment wheels.
Old Dec 23, 2004 | 05:04 PM
squirrel's Avatar
You would be much better off running the One Ton Garage 10 mm axle spacers.
But then again, some "expert" will come along and second guess me.
Old Dec 23, 2004 | 05:38 PM
axiom's Avatar
Great! Thanks!
Old Dec 23, 2004 | 05:44 PM
uncompiled's Avatar
You keep saying that you're not an "expert", but you stayed at a Holiday Inn? Is this a CA/regional thing? I haven't seen anyone denounce your advice on these forums yet...
Old Dec 23, 2004 | 05:49 PM
Dewmerz's Avatar
Don't worry I am not second guessing you. :D
Can someone clear up this question for me? Epitrochoid said in this thread and the other one he is running 5mm hub shims from Van but when I look at Van's site he only has 10mm listed. Is there a 5mm shim (not wheel spacer)? I want to order a set of the shims soon but want to be clear on what I am getting.
Old Dec 23, 2004 | 06:08 PM
OPPS! Sorry guys, the SHIMS are almost 10mm and not 5mm. I confused myself. :D
my06tc
Jun 25, 2015 12:18 AM
scionhawaii
13
Jun 19, 2015 03:59 PM
scionlife
371
Jun 2, 2015 11:00 PM
kleecker
Jan 2, 2015 08:09 PM
umnitza
Dec 1, 2014 06:26 PM
