Register Forgot Password?
Reply
Old 10-26-2008, 12:56 PM   #1
web
web's Avatar
web 30/M
Send a message via AIM to web
Default REVIEW: Agency Power stainless steel brake lines
Along with my clutch line install, I installed my stainless steel brake lines I purchased through Carcandy. Scale of 1-10 for install...without pressure bleeder maybe a 4, WITH pressure bleeder a 1.
Install on these lines are very simple and straight forward. There is a DIY for both clutch and brake lines in the DIY section if you're interested in reviewing it.
Stock pedal pressure leaves something to desire so I wanted to see how stainless steel lines helped out. Again, a few weeks ago I flushed the fluid from the lines with my pressure bleeder and felt a slightly more firm pedal due to the new fluid. After the 160 miles between yesterday and today, I was able to test out the lines for the most part and like them. I haven't done any really hard stopping though b/c yesterday the hand of God opened up and dumped water on my area. For the most part, I was babying the car through a fog of rain that you could barely see the nose of your own car in.
I will be further testing them out today but from what I've driven so far, they do feel a little firmer than stock lines and I don't feel the excess flex in the line when sitting at a light and adding a bit more pressure. Normally, there's an "allowance" on the hydraulic system that relieves the pedal pressure if you're forcing more pressure than the lines can hold....that gives you a bit of a squishiness when you're holding the brake pedal down and sitting still. These don't really allow that pedal to move much more so they seem to be doing their job.
http://theshadow.Web.clubsciontc.com
..those who can, do....those who do are never forgotten.......those never forgotten become Legends
web is offline   Reply With Quote
Old 10-27-2008, 12:22 PM   #2
web
web's Avatar
web 30/M
Update:
Drove a good bit more yesterday and was able to test out their stopping ability on dry pavement. I really don't feel a great deal of improvement with these lines but at the same time, there IS a little. Being able to apply a little less pressure when sitting on a hill is nice if your legs are tired from exercising. I came to an ABS stop yesterday and it was about the same as OEM but pedal pressure, again, was reduced on my part. So far, they seem to be pretty good and I have no issues.
Old 10-27-2008, 12:45 PM   #3
digndoug
digndoug 113/M
Did you by chance try using synthetic brake fluid? I did SS Brake lines with synthetic fluid, I want to say I noticed a difference, but it honestly was not a lot. The pedal feels a tighter, and not as ... maybe soft/sloppy. I'm sure it would be better if I also upgraded the pads, I'm still on oem with plenty of ware left.
digndoug is offline   Reply With Quote
Old 10-27-2008, 01:03 PM   #4
web
web's Avatar
web 30/M
Forgot to mention my setup...oops
EBC Redstuff pads
EBC dimpled/slotted rotors
SS lines
DOT 3/4 Valvoline synthetic brake fluid
Full system flush with pressure bleeder.
Old 10-27-2008, 01:28 PM   #5
jsingh
OhioScions
jsingh's Avatar
jsingh 22/M
Send a message via MSN to jsingh Send a message via Yahoo to jsingh
so if i want to improve the brake system, i would have to get new brake lines, pads, fluid (synthetic).
and would the new rotors help?
jsingh is offline   Reply With Quote
Old 10-27-2008, 01:34 PM   #6
digndoug
digndoug 113/M
Lines, Pads, Fluids will all help. Rotors.. you wont see any real gain at all, Unless you get larger,which means you get a big brake kit or the relocated kit, which I dont see worth while unless you are doing auto-x on weekends.
I spent $80 on SS lines(bought new from other member that did not install) then $12 on Fluid and maybe 2 hours with the g/f's help.
I didn't do pads yet, cause I still have half oem left, but dif after driving hard, give in to heat stroke quick.
Old 10-27-2008, 03:38 PM   #7
web
web's Avatar
web 30/M
The only type of rotor setup that I can see giving anything back to the car other than heat dissipation would be a 2 piece rotor. Lighter rotational mass for added wheel rotation.
But yeah, pads/lines/fluid usually help the brake system out the most. But remember, the mainly think controlling the pressure in the system is the master cylinder so although other parts are replaced with performance upgrades, that's the hydraulic pressure center. If that's weak, the rest won't work at their optimum level of performance.
Old 10-27-2008, 03:46 PM   #8
digndoug
digndoug 113/M
If your replacing your rotors for what ever reason, use 2 piece Brembo Blanks.
Pads will make the biggist dif, but more so for composite and heat stroke. Really, If you dont do hard braking/driving or auto x You are best off sticking with an close to oem. Because nicer brakes ware much quicker as well, become more effective when they are heated up.
Old 10-27-2008, 05:18 PM   #9
toeveryhour
Super Moderator
SuperMod
toeveryhour's Avatar
toeveryhour 28/F
toeveryhour
I'm gonna go this route come spring. Web, can I ask how much you paid for the brake lines?
From the beginning until now... <--My tC Progression thread
Turbo tC: Never Enough <--My Canibeat feature
toeveryhour is offline   Reply With Quote
Old 10-27-2008, 05:56 PM   #10
web
web's Avatar
web 30/M
Quote:
Brake lines alone were 130$ from www.Carcandymotorsports.com
Old 10-27-2008, 10:45 PM   #11
jBoRiCuA
jBoRiCuA's Avatar
jBoRiCuA 24/M
How much did you spend on the whole setup? Probably ALOT cheaper than buying the StopTech Stage 2 Kit..
http://www.nurspec.com/ProductDetail...Slotted-Rotors
For Sale:
-Part Out Thread!
jBoRiCuA is offline   Reply With Quote
Old 10-28-2008, 10:05 AM   #12
web
web's Avatar
web 30/M
60$ rear red stuff pads
90$ front red stuff pads
165$ front dimpled/slotted EBC rotors
135$ rear dimpled/slotted EBC rotors
130$ agency power lines
10$ brake fluid
Total: ~590$ but I can see that prices have gone up about 15$ for rotors since I bought them and 10$ for pads since I bought them.
My price was: ~540$....plus, my rotors are not completely drilled through (which is NOT a good idea for cast rotors) so cracking due to heat around the drilled holes is not a major factor in mine.
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
agency, brake, dif, line, lines, opinions, power, review, scion, ss, steel, tc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
