Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Drivetrain & Power
Register Forgot Password?
Reply
Old 10-28-2008, 02:59 PM   #1
jwaggz82
jwaggz82's Avatar
jwaggz82 31/M
Default tC CEL- Camshaft position sensor - tC
Ok so my cell came on and I brought the car to autozone to get the code read. It was raining out and I still was able to get the lady to let me use the device (they said they wont go out when its raining) - to make a long story short I have the name of the code but totally forgot to get the actual code. The name is: camshaft position sensor
My car is running but if i dont start moving w/ the rpm's higher it will stall. Also, it idles a tad too low then comes back up so it doent stall. Someone please give some info on the topic. I hope the sensor is just gone and I dont have any cam issues. I don't know what symptoms I would have w/ a bad cam (becides the car running horrible). As soon as im moving the car is fine - no issues at all. This is just an issue w/ being stopped and getting out of first gear.
FOR SALE: Scion tC $5500 w/ engine issues but w/ $5k+ in options
(including limited slip, new pads/tires/rotors): Click Here
FOR SALE - PM ME FOR DETAILS:
1.) 2005 Strupp Header that is Jet-Hot Coated!! $250/shipped&insured!!
2.) 2005 S/C Injectors & Stock tC injectors!! (almost new)
3.) Subwoofers & 4ch amp
4.) 2005 Stock tC exhaust (almost new)
jwaggz82 is offline   Reply With Quote
Old 10-29-2008, 03:17 AM   #2
jimmyjun
jimmyjun 30/M
Send a message via MSN to jimmyjun
then replace the sensor
201whp N/A ,surely not over yet.....
jimmyjun is offline   Reply With Quote
Old 10-29-2008, 03:32 AM   #3
UNiT_xEr0
UNiT_xEr0's Avatar
UNiT_xEr0 25/M
i have the same issue but i just clear it with my scanguage. my car is turbo'd and tuned with AEM FIC and my friend told me that most 07's get it unless you run greddy emanage. someone can correct me but my car runs fine with the code poped up, doesnt stall or anything
. : |BPautosound|LEDmod|Arc Audio|A Spec| : .
UNiT_xEr0 is offline   Reply With Quote
Old 10-29-2008, 11:32 AM   #4
jwaggz82
jwaggz82's Avatar
jwaggz82 31/M
^my car is running choppy though. I have to get it into the dealer. The darn code went away just last night - but its running choppy. ..... Its either the sensor or the cam setup - there was a bulletin on the 05's
Old 10-29-2008, 11:52 AM   #5
B_Real45
B_Real45's Avatar
B_Real45 32/M
I doubt it's the actual cam. It will most likely be the sensor.
Rob
Turbonetics Kit
Dezod Sleeved Short Block
Dezod Ported & Polished Head
Siemens 840cc
Hydra EMS 2.6
Awesome Quote removed as per highvoltage's request
B_Real45 is offline   Reply With Quote
Old 10-29-2008, 12:33 PM   #6
jwaggz82
jwaggz82's Avatar
jwaggz82 31/M
^ im not sure because there was a bulletin on my vin for a piece in that area - i forget which part it was
Old 10-29-2008, 04:59 PM   #7
UNiT_xEr0
UNiT_xEr0's Avatar
UNiT_xEr0 25/M
my car runs like a champ with the code on haha, are you running an engine management system like greddy or aem?
Old 10-29-2008, 05:09 PM   #8
BAMF4Life
BAMF4Life's Avatar
BAMF4Life 22/M
what sensor is this... not an o2 right?
-Matt
2007 Scion tC 5Speed
Flint Mica
Tsudo Header and S Pipe
Tanabe Concept G
Injen CAI
BAMF4Life is offline   Reply With Quote
Old 10-29-2008, 05:21 PM   #9
jwaggz82
jwaggz82's Avatar
jwaggz82 31/M
nah - its the camshaft one - im bringing my car to the dealer - i dont see this going well. ill post back -they will look at it tomorrow when the main guy gets in.
Old 10-29-2008, 05:25 PM   #10
UNiT_xEr0
UNiT_xEr0's Avatar
UNiT_xEr0 25/M
keep me updated i'm pretty interested. the code was P0335 right?
Old 10-29-2008, 10:30 PM   #11
WendysOrBust
WendysOrBust's Avatar
WendysOrBust 25/M
Send a message via AIM to WendysOrBust
I would get it once in a blue moon when I had my camcom installed, awkwardly enough it only happened during hard right turns.
07 SW TC-
WendysOrBust is offline   Reply With Quote
Old 10-29-2008, 11:52 PM   #12
jwaggz82
jwaggz82's Avatar
jwaggz82 31/M
Quote:
im not sure what the actual code was - thats the issue - the car is at the dealer now anyway so we shall see what happens
Old 11-05-2008, 04:49 PM   #13
adwoan
adwoan 31/M
If your car runs (properly, at least) you don't have any issues with the cam itself. If the engine code says it's the camshaft position sensor, then (if anything) that's what's out on it.
Most likely, what's happening, is your VVTI is acting up, causing the camshaft to be stationary, instead of adjusting based on rpms. I.E., at idle speeds, the cam should be adjusted to, for example "0" - and at WOT, it should be "10." (VVTI) Instead, it's stuck at 1, or 2, because the sensor is acting up.
Change the sensor (should be pretty inexpensive and easy to do), and if that doesn't work it's most likely:
1. Leaky EGR valve - can cause your car to idle low, high, or rough (and the CEL for cam is unrelated to the idle issue)
2. Vacuum leak (can cause idling issues, and possibly be related to the cam CEL)
3. Idle speed needs to be adjusted (have you done anything under the hood lately, where you might've bumped the idle speed adjustment screw?)
There are probably a couple other things that I'm not pulling out of my head right now, but those three are the most common.
Keep us updated!
adwoan is offline   Reply With Quote
Old 11-06-2008, 08:17 AM   #14
buickid
buickid's Avatar
buickid 22/M
Send a message via AIM to buickid
If I'm not mistaken, idle has been electronically controlled on most modern cars for a while now.
2005 Scion xB
Headunit: Kenwood eXcelon KDC-X996
Front stage: TruTechnology S44 (200x2@4Ω Bridged) / RE Audio RE6.5C 6.5" Components
Rear stage: Massive D800.4 / Pioneer GM-5400T / Pioneer TS-D1702R 6.75" Coax / 2x RE Audio REX6.5 6.5" Coax
Sub stage: 4x Sundown SAZ-1500D (0.5Ω each) / 4x RE Audio SX 15
Electrical: Mechman 270A / 2x DieHard Platinum Group 31 (Odyssey PC2150) / DieHard Platinum Group 35 (Odyssey PC1400) / 2x Custom 150Ah
buickid is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
2005, 2006, cam, camshaft, cel, code, find, located, location, position, replace, scion, sensor, shaft, tc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
