Scion xD Aero & Exterior Aero parts and exterior dress items...
huge HID question....
Old Oct 29, 2008 | 04:13 PM
XLR8R's Avatar
Default huge HID question....
i got my kit in yesterday and hooked one side up and it comes on for like 2 sec and then flickers and shuts off. i was told it was because the car is not reading a halogen bulb in the socket. i was wantin to know what the part was i needed to fix this and where i could get it?
thanks.
Old Oct 30, 2008 | 02:21 AM
pickledchang's Avatar
are you powering the ballasts off of the stock wiring harness, or are you using direct power from the battery with a relay? when a ballast starts up, it has a spike in voltage to "ignite" the bulb, and shortly afterward, it drops the power back down as less is needed to keep the bulb lit. it sounds like you arent getting enough power to the ballasts. check your ground points and/or switch to using direct power off of the battery with a relay setup if you arent already.
Old Oct 31, 2008 | 10:59 PM
Runawayrogue's Avatar
You may want to try testing with both bulbs installed as well. It may be that the different voltage requirements for the two different lights may be throwing off the electrical.
Old Nov 2, 2008 | 04:38 AM
XLR8R's Avatar
thanks guys, i found the problem though, it was the bulbs outlet. the company had a batch of h4 bulbs that had the prongs in the wrong spots. so i just had to pop them out and switch them around.
BlingSlade
Oct 19, 2016 12:39 AM
sciontc008
Scion tC 1G Aero & Exterior
Jan 20, 2016 05:10 PM
BlingSlade
Nov 20, 2015 06:56 PM
Guilles_Tc
Scion tC 2G Aero & Exterior
Oct 15, 2015 03:09 AM
Renuco612
Sep 16, 2015 09:01 AM
