Questions about ECU reset...
Old Dec 24, 2004 | 06:50 AM
cartier001's Avatar
Default Questions about ECU reset...
Should I reset the ECU while the engine is hot or cold?
What should I do after reset the ECU? Let it idle for minutes or hit the road?
Any help would be appreciated.
Old Dec 24, 2004 | 06:54 AM
sexyscionlover's Avatar
i dont think the temperature would matter much, but just incase i might start it in a garage. everytime you reset it im told you should let it idle for a couple minutes, then get going. i guess it has to readjust. that may be old wives tales but i do it any how
Old Dec 24, 2004 | 05:10 PM
Craig_X1's Avatar
Can I ask why you're resetting it?
Old Dec 24, 2004 | 05:19 PM
cartier001's Avatar
I had reset it couple times and I drive the car immediately afterward. I'd found the car is running rich gas mixture. and I smell gasoline from the back of the car at cold start up.
Old Dec 24, 2004 | 05:24 PM
dgHotLava's Avatar
after you reset the ECU the emissions need to re calibrate...
the exhast needs to be hot so that the sensors by the cat. read properly...
but as it a learning ecu it should adjust either way....
Old Dec 24, 2004 | 06:05 PM
cartier001's Avatar
What a Pro. thanks for your info.
Old Dec 24, 2004 | 08:42 PM
yeah every time you reset it just learns quicker than if u change something and do not reset. it( the ecu) has a learning curve and will adjust to your driving style for best perf and economy. (to an extent . it's factory you can't ask for too much)
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
