K&N or TRD drop in filters
Old Dec 26, 2004 | 07:57 AM
jimmydenfield's Avatar
Default K&N or TRD drop in filters
do either of these air filters have any audible improvement over stock? possible slight performance gain?
Old Dec 26, 2004 | 03:31 PM
mach5's Avatar
no the only good part is that they can be cleaned
Old Dec 26, 2004 | 04:07 PM
grnxb's Avatar
I think they usually claim 5hp or so, but the real improvement is on the wallet. I have a k+n in my truck and it has paid for itself because it is reusable. Especially wise if you drive in dusty areas.
Old Dec 26, 2004 | 08:02 PM
smurf3642's Avatar
He ain't kidding...
Old Dec 26, 2004 | 08:11 PM
George's Avatar
K&N filters are a religious issue and the subject of endless debate.
I used them when I was racing motorcycles off-road and they were the best for that application. The reason is that they would never clog up and cause a DNF. The down side of this is that K&Ns would pass a lot of fine particulate, but since I rebuilt my engines frequently I didn't care. DNFs don't pay purses, so the emphasis was on finishing the race. The fact that K&N paid contengency money was also a factor.
For a street driven car I wouldn't run a gauze filter. You can buy a heck of a lot of stock paper filters for the cost of a rebuild. Paper filters provide a physical barrier to all particles above a certain size, which is what is needed for long engine life. They aren't "kewl", but they are the best for the job.
George
Old Dec 27, 2004 | 02:21 AM
cad455's Avatar
a drop-in filter, and removing the secondary charcoal filter, will give the intake a bit of growl, but expect negligible hp loss/gain.
so, yes and no.
Old Dec 27, 2004 | 02:48 AM
jct's Avatar
jct
never heard of the charcoal filter where is that located at???
Old Dec 27, 2004 | 02:52 AM
cad455's Avatar
open your airbox and look up
Old Dec 27, 2004 | 06:56 PM
nero_tC's Avatar
George
so basically the K&N and TRD air filters are pointless unless you want a little growl? i was about to get one. but its better to stick with the stock air filter?
Old Dec 27, 2004 | 07:44 PM
cad455's Avatar
stock paper air filters will always be the safest form of intake filtering.
Old Dec 28, 2004 | 04:02 AM
George's Avatar
IMO, the stock setup is best for an engine in normal street use.
Old Dec 28, 2004 | 06:09 AM
nero_tC's Avatar
I know this is kind of off topic but what about the TRD oil filters. Does the same go with that? Is it better to stick with the stock oil filters also? Or is it worth to pay a couple bucks more for a perforance TRD oil filter?
Old Jan 2, 2005 | 01:41 AM
txjcb's Avatar
I have used the K7N drop ins and the full kit (Sonoma 4.3L). The full kit with low drag toobs give you a good sound and I almost unnoticeable low torque increase. Yes the are reusable BUT they do not filter out the air pollutants nearly as well as a paper filter, this is why it has more air flow. To keep the motor from wearing as fast use the paper filters.
Old Jan 3, 2005 | 05:28 PM
Stefan_TC's Avatar
Default K&N PART NUMBER
Anyboyd has the K&N drop-in filter part number?
Thanks
PS. I am a big fan of K&N filters. They are great. Not to the point that there is difference on a dyno but definetely you can FEEL the difference. At least this was the case in all the cars I've driven so far.
Old Jan 3, 2005 | 05:49 PM
Buzzkill's Avatar
Default Re: K&N PART NUMBER
If there is no difference on a dyno, then can you elaborate EXACTLY what it is that you feel? I'm thinking of getting one, but I have a suspicion that anything can be felt. I just want it to be re-usable.
Thanks.
Old Jan 3, 2005 | 05:57 PM
Stefan_TC's Avatar
If there is no difference on a dyno, then can you elaborate what it is that you FEEL? I'm thinking of getting one, but I have a suspicion that anything can be felt. I just want it to be re-usable.
Thanks.
Buzz,
"Feel" meaning responsivenes; you press the pedal to the metal and the torque appears that little split second sooner....
K&Ns hav as many followers as critics. Buy one, they are not that expensive and you will know right away. Just do not put the K+N sticker OUTSIDE the engine bay 'cause that's pure "rice" and you definetely want "race" not "rice"
Old Jan 3, 2005 | 06:23 PM
Stefan_TC's Avatar
Default K&N AIR FILTER PART NUMBER: 33-2252
K&N part number is 33-2252
http://www.knfilterchargers.com/sear...x?Prod=33-2252
33-2252 Product Specifications
Product Style: Panel Air Filter
Height: 0.938 in (24 mm)
Outside Length: 11.375 in (289 mm)
Outside Width: 5.938 in (151 mm)
Filter Re-Oiling Amount: 0.83 oz (24 ml)
Weight: 0.8 lb (0.4 kg)
Product Box Length: 13.5 in (343 mm)
Product Box Width: 7.75 in (197 mm)
Product Box Height: 1.75 in (44 mm)
Old Jan 3, 2005 | 07:21 PM
George's Avatar
I kind of question what would be different about a "racing" oil filter. Oil pumping losses in an engine are trivial, so a freer-flowing filter would not yield an improvment. It would yield a bit more oil pressure, but since all modern oil systems have an oil pressure control/relief valve that advantage would be lost.
OTOH, if the filter had a finer hole pattern, it would filter slightly better, but the particles filtered would be too small to make much difference.
Now, there are "racing" oil filters (Fram HP-1, for example) that are built to take more internal pressure than stock filters, but a stock Scion doesn't need this capability.
I'd say that if you change oil and filter at the recommended intervals, the standard filter is fine. I don't see any advantage that the TRD part could have over the stock part.
George
Old Jan 3, 2005 | 09:39 PM
Stefan_TC's Avatar
George
I was a SAAB fan in my past life and SAAB oil filters are equipped in back flow valve i.e. oil can only flow one way (the correct way). I think K&N oil filters have the same functionality. How about Toyota and TRD filters?
airmankevin1
Feb 14, 2018 01:23 PM
danielv
Aug 26, 2015 07:14 PM
Scion0814
Feb 12, 2015 01:41 AM
JPuehl
Jan 10, 2015 01:01 AM
Godfryness
Jan 2, 2015 11:18 PM
