Wheel spacers?
Old Dec 27, 2004 | 07:53 PM
Bsbox's Avatar
Default Wheel spacers?
Has anyone out there put the spacer shims on the rear of their xB? I like the looks of the kit from onetongarage.com but i'm not sure if it's really worth it or if it's even safe. I've also seen the spacers that require longer studs and i hate the thought of those even though many cars and trucks have them. I just want a sportier look by pushing the rear wheels flush w/the fenders. If you have tried these let me know they work.
Old Dec 27, 2004 | 08:04 PM
squirrel's Avatar
Default Re: Wheel spacers?
Van's spacers are safe. I know peeps that have been running them for as long as Van first introduced them. The OTG spacers are first rate quality, and as good as, or better than, the spacers found in Japan.
Old Dec 27, 2004 | 08:23 PM
i'm runnin em and i love em. nothing like pushin those rear tires where they belong.
Old Dec 27, 2004 | 08:26 PM
Bsbox's Avatar
Ok so the OTG spacers are good. Now if i put them on will the dealer notice and if they do will i get in trouble?
Old Dec 27, 2004 | 08:27 PM
squirrel's Avatar
you will only get into trouble of the modifcation you did was the cause of the broken or damaged part.
Old Dec 27, 2004 | 08:45 PM
CBSIMONSEZ's Avatar
I have had them installed for over 6 months and about 8 K miles, and no problems. Chances are the dealer wouldnt even know what they were, even if he did find them on your box.
Old Dec 28, 2004 | 01:08 AM
scionce's Avatar
shims are awesome. 8 months and 20k.
does anyone know of the correct studs to use however, if running a 10mm spacer? i thought i read somewhere on this forum that there were studs from toyota that would work. i tried looking for the thread but the search function sucks here.
Old Dec 28, 2004 | 01:27 AM
rollotomassi's Avatar
Hey Bsbox,
I'm running the OneTonGarage rear hub spacers and I'm completely confident in their safety. The kit actually spaces the hubs out from the rearend & widens the track width 10mm (about 3/8") on each side. I could add the wheels spacers too, If I wanted.
I've dealt with wheel spacers before and OneTon's are some of the safest that I've seen. Billet aluminum is rather strong & their fit appears to be precise. A tight fit is rather important in this situation.
I highly recomend the hub kit that I'm running. Install took about 20 minutes and it only set me back $60. Chump change!
terrye
Jan 25, 2015 05:31 AM
CAtC12
Dec 23, 2014 04:44 PM
avus
14
Aug 6, 2004 09:27 PM
scionara
38
Feb 25, 2004 04:52 AM
Hardhitten
Nov 2, 2003 08:29 PM
