Turbo Q's
Old Dec 29, 2004 | 06:13 PM
Z34RedSox's Avatar
Default Turbo Q's
If I was to put in a turbo, how much life could I expect out of my car? Some people are saying 50,000 miles tops... but that sounds a bit shallow for a toyota? Anybody know anything about it?
Old Dec 29, 2004 | 07:06 PM
Ashe_WCM's Avatar
DeepSouth Scions
How long would the tires last? depends on the tire and useage. I figure my Stock tires are going to last me 15K miles or so, of course I dog the hell out of my car. (At least for another 70K miles ;))
Old Dec 29, 2004 | 07:11 PM
dgHotLava's Avatar
Default Re: Turbo Q's
it really a loaded question....
how do you plan on driving it???
how much boost are you talking???
what other upgrades to compensate for high HP and boost???
Old Dec 30, 2004 | 02:22 AM
scionkeychains's Avatar
deff more than 50k man...
Old Dec 30, 2004 | 10:33 AM
dgHotLava's Avatar
still depends on my questions.....
if you try to throw 28-30 psi on a stock motor, don't expect it to last the day....
Old Dec 30, 2004 | 10:41 AM
ProtoCulture's Avatar
Agreed. Depends on boost. In a low boost situation, you'll have near stock dependability.
Old Dec 30, 2004 | 01:15 PM
Simez2003's Avatar
how about with 10-12 psi ?
Old Jan 1, 2005 | 01:54 AM
Z34RedSox's Avatar
how much hp is 6 psi
Old Jan 1, 2005 | 02:45 AM
unlmtdndeavor's Avatar
psi is just the pressure rating. it does not have a geometric ratio to hp. a lot of other stuff such as what kind of fuel management will also come into play when u raise the pressure.
Old Jan 1, 2005 | 08:07 AM
KingLou's Avatar
That question is hard to answer because so much will affect the actual HP delivered by 6psi of boost......as unlmtd said, fuel management for instance. BUT....a "general" rule of thumb for a correctly done turbo charger is to expect about 8-9 hp per psi (this is usually crank horsepower). So.....for 6 psi, you can expect about 48-54 hp if set up properly. Remember though.......this is HIGHLY generalized, and there can be VAST variation depending on set up.
KiL
Old Jan 12, 2005 | 11:18 PM
sciontificxb's Avatar
another thing you have to remember is that the stock engine in the xb was not initially designed for a turbo so it will probably add more wear and tear on the engine, just my $.02
Old Jan 12, 2005 | 11:56 PM
squirrel's Avatar
Your xB won't last long if plan on having more than 7 psi. That and the fact that the injectors, and fuel pump won't be able to keep up. The OEM ECU is only good for normally aspirated engines. The code needs to be cracked first, or some sort of system to piggyback it.
Old Jan 13, 2005 | 01:47 AM
screw fuel , that all can be fixed it's the fact that the rods can only last about 50k on 7 psi if driven hard , they are weak . unfortunatelt, stroke it and use better rods and bam u got reliability there.
SloTC1
Aug 16, 2018 02:45 PM
greytc
Oct 26, 2015 07:53 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
JonathonK
Sep 22, 2015 07:27 PM
