Turbo Install Starting Next Week
Old Jan 1, 2005 | 02:20 AM
crestronwizard's Avatar
Default Turbo Install Starting Next Week
All my parts will finally be here by tuesday. I am planning to post pics of the fabrication. I have talked to several companies including the guys that supplied the big thumper for our race car and no one has a working, tested, proven Scion xB kit so we are going to put together our own. I hope this will help others. Look for posts starting mid week. Happy New Year!!
Geoff
Old Jan 1, 2005 | 02:43 AM
unlmtdndeavor's Avatar
good luck, cant wait to see the results
Old Jan 1, 2005 | 03:54 AM
Bleach3-0's Avatar
Yes I hope you post the results, what kind of turbo is it? I am going to be getting a Greddy one with my tax return, so I am pumped to see what its like.
-J
Old Jan 1, 2005 | 04:10 AM
rotarycolt's Avatar
Been there, done that. The tough part is getting a good fuel management setup. Have fun. BTW 2zz injectors will drop in... I was the first to try it, and it works
Old Jan 1, 2005 | 01:13 PM
Cool.........did you ever post results, pics, etc? Any upfront insight would be great. Thanks
Old Jan 2, 2005 | 06:09 PM
rotarycolt's Avatar
Started out with the TSI kit, ended up keeping nothing but the piping and intercooler. Fuel management wise, a 1:1 RRFPR in the tank, 2zz injectors, and Greddy e-manage should set you up just fine. Turbo wise, the T series are ok, but GT series are much better. GT25R is my turbo of choice, fast spooling on a 1.5L. Good for up to 240hp if you decide to build the bottom end up. Oil return line... very tough to do on a transverse mount engine, especially when it has a .5" oil pan. You have to tap the lower engine girdle. The biggest issue being the axles. Be sure to mock up your line while the car is on all 4's, try jacking it up and putting ramps under all 4 tires. This way you can see where the axles are when the car is on the ground. The angle of the oil return is very important, and very tough to get right on these cars with the limited room. If you have to use any 90 degree bends, make sure none of the straights are perpendicular with the ground. Be sure to use 1/2 - 5/8's line for the return. The return line is often passed up, but is extrememly important... high flow in, and low flow out will result in blown seals. This can make boost go crazy, and oil can be passed in the intake and exhaust. Use an oil restrictor fitting on the oil INLET to minimize any risks, turbos need relatively low oil pressure to survive... 15-20lbs is more than enough.
Sorry for the lack of structure, I'm getting ready to get in the shower, it's time to goooooooooooo.
Old Jan 2, 2005 | 07:18 PM
fusionscion's Avatar
keep us all posted..... i really want to turbocharge my xb,,, im getting frustrated and straight up ____ed off about the power situation...... keep us posted though 4 reeeaal
Old Jan 18, 2005 | 12:53 AM
Hi All, Finally back from a businees trip. the Turb has arrived and the Intercooler is here. I am going to a standalone fuel management. This makes sense for me since that is what we run on our big car and will be easier for me. The mockup starts this weekend and I will post the good and the bad. Also, what is everyone's opinion on the best first event to go to on the east coast? Thanks
Old Jan 18, 2005 | 02:40 AM
hey i think u should go to the hin event coming up in april..... ill be going to that with my xB, not turboed but ull have some goodies...... keep me posted on the kit..... would you be willing to replicate the kit if it proves bigger numbers than the stock hp? let me know what you decide.......
Old Jan 18, 2005 | 02:42 AM
you should attend the hin show in boston, april suttinith..... keep me posted on the kit, would you be willing to replicate the kit if it is a success? let me know..........
Old Jan 18, 2005 | 02:48 AM
depending on a lot of factors, yes , I would be willing to replicate the kit. It would have to be after track tests so lets see how it all goes.
Old Jan 18, 2005 | 02:57 AM
yeah thats cool, keep me posted on that.................p
Old Jan 18, 2005 | 02:58 AM
EvalEvan66
Jan 27, 2015 02:26 AM
cid_mcdp
Jan 5, 2015 02:45 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
ScionLife Editor
Nov 25, 2014 03:00 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
