manual transmission
Old Jan 8, 2009 | 06:51 PM
chintastictc's Avatar
Default manual transmission
can someone go out and drive and let me know where each gear tops out at? or make a video...cuz i own a tC and i believe u xb guys have a different gear ratio that the tC allowing you to have longer gears...if im right that will open up a whole new ball game for tCs, and turbo xBs..thanks i hope i get a response soon
Old Jan 8, 2009 | 06:58 PM
DAILYXB-TYPE-R's Avatar
the last time i've check is each gear have the same run as the 1st gen but we just get there a bit quicker
Old Jan 8, 2009 | 07:01 PM
compared to a tc....im in 5th gear at 3krpm doung 60 mph...if im assuming correctly at 3krpm you should be around 75-80mph
Old Jan 8, 2009 | 08:35 PM
more like around 70mph i'll double check it later
so whats yours max mph at redline for each gear?
Old Jan 8, 2009 | 08:39 PM
3rd-80...4th-110...5th-135
Old Jan 8, 2009 | 11:58 PM
bump
Old Jan 9, 2009 | 12:23 AM
tainoxl's Avatar
I'm not sure they are geared any different if the transmission is the same as for model or pn. Also good luck with someone risking a ticket jut to do wot runs and figure out gear ratios. I think a little research on tranmission part number/model would be a better route for comparison. Either way they are still pretty short. Good luck.
Old Jan 9, 2009 | 12:27 AM
yeh i did...and i found the final drive is different
Old Jan 9, 2009 | 12:39 AM
tainoxl's Avatar
That sounds about right given the size and utility of the XB2. You may benefit more from a raised rev limit. It all depends what kind of driving are you going to do. If its a better ratio combined with a raised rev limit might be interesting.
Old Jan 25, 2009 | 03:15 PM
twocamvw's Avatar
speedo readings @ 3000rpm
1st/15mph 2nd/27mph 3rd/40mph 4th/55mph 5th/70mph
assuming 6000rpm.
1st/30mph 2nd/54mph 3rd/80mph 4th/110mph 5th/140mph.
hope this helps
Old Jan 26, 2009 | 04:30 AM
your tc max at 135?
i can bearly get mine to 130 before i have to brake
Old Jan 26, 2009 | 04:48 AM
jct's Avatar
jct
limited to 127 for the tc
Old Jan 26, 2009 | 04:51 AM
Rockztar's Avatar
MAX TEST SPEED
I - 33 mph (6500 rpm)
II -58 mph (6500 rpm)
III - 88 mph (6500 rpm)
IV -121 mph (6500 rpm)
V -124 mph (5000 rpm)
there u go..
draxcaliber's Avatar
i'm pretty sure the owner's manual tells you the maximum possible speed in each gear.
Old Jan 26, 2009 | 06:17 PM
bego's Avatar
I thought I heard somewhere that the xB2 governs at 103... is that not true? I got mine to 100 or 101, but not any further. I cant quite remember what rpm I was running at, but it doesnt seem like my second gen will do more than 130 or 135. correct me if I am off please
Old Jan 26, 2009 | 08:31 PM
AAG's Avatar
AAG
DeepSouth Scions
Not true, I've had mine over that speed before
Old Jan 26, 2009 | 08:55 PM
Zsanz's Avatar
x2
had it up to !@#
Old Jan 26, 2009 | 09:22 PM
thanks guys it looks like only the fifth gear is longer
Old Jan 27, 2009 | 01:16 AM
renegade4x4's Avatar
Does this help?
http://www.caranddriver.com/content/...B_08_rt_ss.pdf
Old Jan 27, 2009 | 02:24 AM
so the xb2 is drag limited versus the tc being being electronically limited at another 3 mph.
does that mean that the xb2 doesn't have a govenor on it like the tc does?
