Megan header, Invidia S-Pipe, and Skunk2 exhaust
Old Jan 16, 2009 | 09:39 PM
KillerZX2's Avatar
Default Megan header, Invidia S-Pipe, and Skunk2 exhaust
Question...Will all this bolt together? I was at the shop today trying to put parts on, and the Skunk2 exhaust will not bolt up to the stock S-Pipe. Wondering if the Invidia will bolt up to the Skunk2 exhaust and to the Megan Racing header.
Old Jan 17, 2009 | 03:55 PM
ESEMRFOZZ13's Avatar
it should all be the oem standard size mounting holes, but make sure you dont get turbo size piping.
Old Jan 17, 2009 | 10:25 PM
KillerZX2's Avatar
It shouldn't be. I didn't see any options for it when I ordered. It's the stock S-Pipe thats to big for some reason. Don't know what the F* Batman..
Old Jan 18, 2009 | 03:22 PM
BlckdOutTC's Avatar
are you re-using the oem donut gasket like you should be?
Old Jan 20, 2009 | 01:13 PM
ecko04's Avatar
He should be using the doughnut gasket off the stock headers to replace on the megan headers. It simply slides off. When you put back on the spring loaded bolts be sure they are tight, hence why you need to reuse that gasket, that will stop any leakage.
The only thing I want to say since I recently did an install something like yours this last weekend, beware of rasp. I am going to have to weld a resonator onto mine.
Old Jan 22, 2009 | 07:29 PM
xzsimmnzx's Avatar
on my skunk 2 i had to grind out the bolt hole on the flange a little bit and then it fit with no problems, just need a little custom work
Old Jan 24, 2009 | 10:06 PM
KillerZX2's Avatar
Just got back from the shop. I had to take a die grinder to the foward most flange on the exhaust. Took a little while, but I finally got it on. It sounds flipping amazing!!
Old Jan 24, 2009 | 11:43 PM
xzsimmnzx's Avatar
glad to hear u got
Old Jan 25, 2009 | 05:49 PM
xdejablu3x's Avatar
want to post some videos?
helloninja
Mar 19, 2018 04:50 AM
That_Kid_Ju
Jun 26, 2015 10:57 PM
LoseControl
Mar 26, 2015 02:24 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
kdanie
11
Jan 23, 2004 04:47 AM
