rattle when decelerating
Old Jan 19, 2009 | 12:42 AM
mattieg's Avatar
Default rattle when decelerating
So whenever I am under heavy acceleration then get off the gas I hear a rattle from the bottom of the car. But as soon as I push in the clutch it stops. Its not very loud, but sometimes I will get a rubber smell from the HVAC. Maybe its nothing major just wanted to ask.
Old Jan 19, 2009 | 12:45 AM
ariese's Avatar
maybe your exhaust
mine was doin what yours sounds like til i tightened up all the bolts
Old Jan 19, 2009 | 12:51 AM
mattieg's Avatar
I sure hope it is. The car has 15k on it and no modifications to the exhaust.
Old Jan 19, 2009 | 01:49 AM
mattieg's Avatar
does anyone else have input? And could it be the s pipe, mid pipe? Which one?
Old Jan 19, 2009 | 03:07 AM
kalvinz61's Avatar
youre not modded, you still have warranty right, you can always bring it to the dealer to tell them, or you can just jack up your car and move the exhaust a litlte and see if it rattles, or look for anything that the exhaust is very close to
Old Jan 19, 2009 | 04:17 AM
mattieg's Avatar
ill crawl under there and see whats up. I need a better jack so i guess this will be my reason to buy one.
Old Jan 23, 2009 | 06:28 PM
ptguy08's Avatar
i had that same problem after i put my header on, and i had 2 straight cel fix pieces on my new wider s pipe, and when i decelerated the cel fix piece was rubbing metal on metal. then i got the angled cel fix piece and it fixed...duno if thats ur prob tho
Old Jan 23, 2009 | 06:38 PM
mattieg's Avatar
i still need to crawl under the car and check it out. I really hope its an exhaust bolt.
Old Feb 23, 2009 | 05:21 PM
mattieg's Avatar
im bumping this thread cause i have crawled under the car and have not found any loose bolts. I hear a rattle when I let off the throttle anywhere above 4000 rpm. And as soon as I push in the clutch the rattle goes away. Its a faint rattle but it drives me insane.
Old Feb 23, 2009 | 05:59 PM
jwaggz82's Avatar
i have sort of a clinging sound ever so slightly at idle and as soon as i tap the gas it goes away instantly. I dont have an engine cover on (not yet) so any chance it could be loud vvti? If my sound didnt go away when i hit the gas i would be worried but it goes right away every time. Also, in real cold weather you can hear it more and in hotter weather you dont hear anything
Old Feb 23, 2009 | 06:02 PM
SW_08's Avatar
i guess just either crawl under the car and see what you find....or just take it to a dealer...
Old Feb 23, 2009 | 06:39 PM
mattieg's Avatar
ya i hit the gas and it goes away, i just hate the dealership with a passion.
Old Feb 23, 2009 | 06:42 PM
SW_08's Avatar
yea but it would get taken care of and since your still under warrenty you most likey wont have to pay anything....just depends what it is....
Old Feb 23, 2009 | 06:59 PM
jwaggz82's Avatar
i spoke to the dealer and they said my car is running perfect and its because of my engine cover not being on and there is no issue. Ive taken care of my car like a baby so I listen for anything and always post. Im like an over protective parent.
Old Feb 23, 2009 | 07:04 PM
jct's Avatar
jct
your just in tune to your surroundings
Old Feb 23, 2009 | 07:47 PM
GQQSE13's Avatar
mine used to rattle when i broke one of the hangers but that was with modified exhaust so i'd def take back to dealer cuz of warranty
Old Feb 23, 2009 | 08:05 PM
jwaggz82's Avatar
^ oh yea that would do it. Mine is very very faint ...nothing like what you were hearing
Old Feb 24, 2009 | 01:44 AM
yellowxhoodie's Avatar
the fact that it stops when you push the clutch in makes it sound like a clutch/flywheel issue, not an exhaust issue...
Old Feb 24, 2009 | 01:53 AM
mattieg's Avatar
i brought it to the dealership today and they said it was a heat shield for the exhaust. and when i pushed in the clutch the RPM's would drop thus making less exhaust come out and not make the rattle. He promised me it was nothing serious and if it was he would warranty it no problem. These guys are mad cool, so when I put my exhaust back on in the spring time I will check.
I think its the brace that the exhaust rests on, in case of the exhaust falling off, that part is suppose to "catch it"
Old Feb 24, 2009 | 02:13 AM
no, if he said heat shield hes reffering to one of the ones under the car, there are several. you could always just rip em off, theyre only held on with rivets if i remember correctly. lol
