Register Forgot Password?
Reply
Old 01-21-2004, 05:53 PM   #1
GenXreject
GenXreject
Default tc maybe
Well what about the tC Eng.? will that drop in? (newbie question) what the eng designation (name) in the xA/xB? and what's the tC eng from?
GenXreject is offline   Reply With Quote
Old 01-21-2004, 06:35 PM   #2
Djuan
Djuan's Avatar
Djuan
Send a message via AIM to Djuan Send a message via Yahoo to Djuan
Default rather stick a celica engine
its from Camry, so I dont think it will fit without some severe surgery... and maybe not even with that... probably better go with celica engine
"We do not have an idea. The idea has us..." -Heinrich Heine, German poet
Djuan is offline   Reply With Quote
Old 01-21-2004, 06:37 PM   #3
Milhamscion
Milhamscion's Avatar
Milhamscion 37/M
better yet, try a hemi!!!!
Milhamscion is offline   Reply With Quote
Old 01-21-2004, 07:17 PM   #4
eric_m
eric_m's Avatar
eric_m
Quote:
i don't think the advantages of an engine with a hemispherical combustion chamber will be as obvious in an engine small enough to fit in the scions engine bay.
the 1.8L celica/matrix/elise engine has around 180hp and will fit better than the 150hp 2.4l camry engine. both are normally aspirated.
eric m.
featured ride: september 2003
eric_m is offline   Reply With Quote
Old 01-21-2004, 07:25 PM   #5
showpaojoe
IV ACE
showpaojoe
Send a message via AIM to showpaojoe
does the ecu monitor the the transmission because you'd have to swap that too right? for it to be street legal and pass. thaz my question for a swap right now
showpaojoe is offline   Reply With Quote
Old 01-21-2004, 08:16 PM   #6
Djuan
Djuan's Avatar
Djuan
Default do it
so what exactly would you have to swap ?
Lets say 1.8 Celica Engine
Transmission
motor mounts
probably some kind of work for the weight of the engine
cut away some of the engine compartment...
what a mess, someone do it ! Click the image to open in full size.
Old 01-21-2004, 08:37 PM   #7
kwicslvr
kwicslvr's Avatar
kwicslvr 41/M
Default Re: do it
Transmission
motor mounts
Weight and cutting the engine. Hmmm... is this a totally different engine or did they just retool the internals to get .3 more liters out of it and raise the compression for more hp. It could very well be the same dimensions on the outside and just a different internal configuration. Even then, size wise a 1.5L engine is going to be about the same size as a 1.8L engine externally I would think. .3 L is not that much at all spread out over 4 cylinders. If the above is true then it would weigh essentially the same if not less for the larger displacement engine. Anybody have any insight on these points.
04 BOP xB
11 F-150 Super Crew/Ecoboost/4x4/Lariat/Tuxedo Black
2001 BMW 330i 54,000 miles on the odo. as of 1/12/13
kwicslvr is offline   Reply With Quote
Old 01-21-2004, 10:25 PM   #8
ncscion
ncscion
Send a message via AIM to ncscion
so could you use a celica head on the xb engine and bore the xb engine to get the xtra .3L?
ncscion is offline   Reply With Quote
Old 01-22-2004, 03:27 AM   #9
GenXreject
GenXreject
I'm new to Toyota, what are all the diff. eng. designations?
What's the echo motor called?
What's the celica motor called?
What's the camry motor called?
What's the size of the celica motor?
Celica motor going to be in Elise?
Old 01-22-2004, 03:33 AM   #10
1NZFE
1NZFE's Avatar
1NZFE
Echo/ xA(iST)/ xB (bB): 1NZ-FE
Current Celica GT: 1ZZ-FE(?)
Current Celica GTS: 2ZZ-FE
late 03-current Camry/2004 Solara 4cyl: 2AZ-FE
Both Celica motors are 1.8L. And yes, Lotus begged Toyota to use the GTS engine (2ZZ-FE) including it's transmission for the Elise.
Heading out West in the BlueBox
1NZFE is offline   Reply With Quote
Old 01-22-2004, 04:14 PM   #11
scibrew
scibrew
Send a message via Yahoo to scibrew
sweeet!
scibrew is offline   Reply With Quote
Old 01-22-2004, 05:53 PM   #12
GenXreject
GenXreject
Default does that thing got a hemi?
I would love to see the first person try to put a Hemi in a Scion. :twisted: You could put it where the back seat is. lol
Anyway, I was wondering, there is a Blitz S/C available for the xA/xB, the factory offers one too right? Do they prepare the engine for S/C or just take a N/A engine and bolt it on? How much boost can the 1NZ-FE handle? (1nz-fe is right isn't it? I'm a newb.) Short of ordering custom parts, what is available off the shelf for performance?
Most importantly, what would you do to your Scion? keep it N/A? Supercharge? Intake/Header/Exhaust mods? Post your thoughts.
How do you change the stock ECU settings? Do you need chip? Flash programme? Piggy-back controllers? How 'tunable' will Toyota make these cars.
How long will the scions be here? is this like a one time offering or are they going to be around for 20 yrs like the civic. ( I hope so)
WHY WONT THEY BE SOLD IN CANADA!!!!
When GM released the Ecotec engine the were the first and largest makers of aftermarket products for it. Same thing with Mopar and the SRT-4 engine. Will TRD do the same thing? If they do, will they give thought to carrying body kits/accessories as well or will they leave that to private companies?
Where do you want Toyota and TRD to take the Scions?
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
24, cutaway, engine, scion
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
