05-06 TPMS help please
Old Mar 11, 2009 | 06:49 AM
graphite06's Avatar
Default 05-06 TPMS help please
so the 05-06 tCs do not have an actual sensor in each wheel, but calculate wheel speed off of the ABS sensor. This is a pointless system since it doesn't actually measure the tire pressure.
I recently had to get 2 new passenger side tires because of potholes and the front left tire now has less tread than right one. I believe this is setting the light off because of the slight change in rotation. Before anyone chimes in about what my tire pressure is, I have it set at 35 PSI in the front and 32 PSI in the rear (on the door it says 32/front and 29/rear, a 3 PSI difference. Since I added a little more air in each but kept it at the 3 PSI difference it shouldn't matter since in theory all the wheels should read equal. When I had all new tires this worked fine) and this has been a problem since I bought the car (used) last year. The only way the light stayed off is when I bought all new tires, or replaced them in pairs. Buying tires is getting expensive...
I can't take the damn light on my dash anymore. it's frustrating when I know nothing is wrong. is there a way to reset it to what i'm running now regardless of tire pressure/wheel circumfrence? I'm sure there isn't a way to turn the system off but maybe change the settings? I'm about to take the friggin' LED bulb out as a last resort...
**EDIT** I did a search and found there was no way to deactivate it, so if anyone has some helpful info on getting it set properly then that'd be great.
Old Mar 11, 2009 | 07:30 AM
O5_TRD_tC's Avatar
I prefer not to have TPMS but anyways there is a way to reset it. Look in your owners manual.
I believe there is also another way to disable the system as well.
Old Mar 11, 2009 | 07:40 AM
SquallLHeart's Avatar
you need to reinitialize the system.. hold button until it the light blinks 3 times..
it's in your owner's manual..
page 110 to be exact... and you can read pages 107-109 while you're at it too.
kleecker
May 22, 2016 06:10 AM
paolodoctolero
Feb 22, 2015 06:35 AM
ptperson
Regional - Pacific Northwest
Feb 13, 2015 04:03 AM
RogerTTR
Nov 18, 2007 10:20 PM
ScionFred
Nov 7, 2007 09:01 PM
