Dynamat questions
Old Jan 10, 2005 | 01:42 AM
Max's Avatar
Max
Default Dynamat questions
Where is a good place to get some Dynamat? By good I mean cheap. What similar products are out there which still do the job?
Also, roughly how much am I gonna need for basically the whole rear of my box and perhaps the doors? I was thinking 100 ft^2.
Before someone goes and says "Try a search" I did. Here and elsewhere. Just curious if there is some magical undiscovered location which sells the stuff for $.04 a foot.
Old Jan 10, 2005 | 02:44 AM
tbone587's Avatar
well I just got the dynamat extreme door kit for my front doors for 30 bucks off ebay.. So I would recomend ebay...
Old Jan 10, 2005 | 03:24 AM
brownbread is just about as good i'd say like 90% and its significantly cheaper , theres also second skin liquid dampening.
Old Jan 10, 2005 | 03:25 AM
Max's Avatar
Max
$30 aint bad. Enough for two doors I am guessing? Are they precut to fit an average door, if so, how close is the fit?
Old Jan 10, 2005 | 11:14 AM
tbone587's Avatar
Yes it says on the box that it includes 4 precut pieces enough to cover 2 average doors. You have to cut them ur self to make them the perfect size.
Old Jan 10, 2005 | 01:31 PM
violent_b's Avatar
I did almost my whole xB yesterday. top to bottom, the doors are the only things left to do. started about 10:30 am and finished up around 9:00pm. it made a BIG difference in road noise. I used the Metra Silencer sound deadening stuff, since I work there it was the smart choice. I used Dynamat before with good results also.
just remember to plug all your wire harnesses back in, I forgot to plug the airbag sensor for the driver side seatbelt and the light came on in the dash. I plugged it back in, took the negative battery terminal off for 15 minuets and reconnected it and POW no airbag light. thank goodness.
Old Jan 10, 2005 | 01:36 PM
hongs66's Avatar
E-Bay is a good place to buy cheap. I did my Xb with Dynamat, used one bulk pck and one door kit. Then I did my Explorer with Fat mat. If you look at the decibel reduction between the two it is almost exactly the same. Fat mat is about 1/2 the price. Bought both off of E-bay.
Old Jan 10, 2005 | 01:38 PM
mikochu's Avatar
I bought some Quik-Fix Roof and Gutter Repair tape by Protecto Wrap at Lowe's. It comes in a 6"x25' roll. It's about 12.95 a roll. It works just like Dynamat, but it's .06" thick. I think Dynamat (the newer sound-reflecting type) is .1". Can't beat it for the price...
Old Jan 10, 2005 | 01:45 PM
grnxb's Avatar
I used b-quiet extreme(by same company that sells brownbread). It was real cheap, went on real easily, and didn't have any odor following installation. I imagine it also helps cut down on road noise and improved speakers. (not for certain of it's effects as I installed everything at once shortly after purchasing the xb)
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
