Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G Forced Induction
Register Forgot Password?
Turbo and supercharger applications...
Reply
Old 03-18-2009, 07:41 PM   #1
sharkattach
sharkattach 113/M
Default tc not running right after installing s/c
ok i got a trd supercharger for my 05 tc. i put it on myself. i when by the book when it came to installing it. took my ecm out to get reflashed. but now i'm having problems. first it will not got up to 6200rpm it cut out at 5500. second when trying to maintain a speed limited it sputters really badly. need some helpfully information on trying to get it running right...thanks
sharkattach is offline   Reply With Quote
Old 03-18-2009, 07:54 PM   #2
ack154
Super Moderator
Super Mod
ack154's Avatar
ack154 32/M
Did you have the dealer do the reflash?
Blog | Pics | Videos | Twitter
HOW TO: SEARCH SL | POST ON SL | NOT GET BANNED
ack154 is offline   Reply With Quote
Old 03-18-2009, 07:59 PM   #3
sharkattach
sharkattach 113/M
yea i dealership reflash it
Old 03-18-2009, 08:04 PM   #4
b52hDUNN
b52hDUNN's Avatar
b52hDUNN 27/M
Thats alot of rpm. Maybe shift prior to 5k, I dont see a reason to go above that, other than to blow a engine. The car should run a little on the rich side, atleast mine does with the s/c.
b52hDUNN is offline   Reply With Quote
Old 03-18-2009, 08:13 PM   #5
2006bluetc
2006bluetc's Avatar
2006bluetc 28/M
Send a message via AIM to 2006bluetc Send a message via Yahoo to 2006bluetc Send a message via Skype™ to 2006bluetc
make sure your fuel injectors are all seated properly
Scikotics Charleston, West Virginia HMFIC
Sponsored By:
Soundstream Audio
NRG Innovations
Air lift Company
2006bluetc is offline   Reply With Quote
Old 03-18-2009, 08:16 PM   #6
AAG
DeepSouth Scions
AAG's Avatar
AAG 27/M
Quote:
If the engine was going to blow then toyota would have lowered the rev limiter. Its obviously not running right if it won't rev to redline (and it won't blow unless you miss shift and over rev it past redline).
OP, is your ride throwing a check engine light? Not sure if this would help but have you tried disconnecting the battery for a few mins and then allowing the vehicle to idle?
'08 Nautical Blue Metallic xB
1 of only 2528 ever built
AAG is offline   Reply With Quote
Old 03-18-2009, 08:18 PM   #7
rosedaleny806
rosedaleny806's Avatar
rosedaleny806 25/M
Send a message via AIM to rosedaleny806 Send a message via Yahoo to rosedaleny806
how many miles on ur car?
rosedaleny806 is offline   Reply With Quote
Old 03-18-2009, 08:31 PM   #8
sharkattach
sharkattach 113/M
98.000 miles on the clock, oh yea in 30 miles i have used up 1/4 tank of gas
Old 03-18-2009, 08:33 PM   #9
AAG
DeepSouth Scions
AAG's Avatar
AAG 27/M
^ quit stomping on it lol
Old 03-18-2009, 08:33 PM   #10
aen
dope dope dope
aen 25/M
Send a message via AIM to aen
sounds like o2 sensor isn't reading the fuel trims correctly, watch for a check engine light and your gas gauge
aen is offline   Reply With Quote
Old 03-18-2009, 08:35 PM   #11
b52hDUNN
b52hDUNN's Avatar
b52hDUNN 27/M
check the trd fuel line that you had to replace. You have a major fuel leak somewhere. Is there smoke coming out the exhaust?
Old 03-18-2009, 08:37 PM   #12
2006bluetc
2006bluetc's Avatar
2006bluetc 28/M
do you smell gas really bad?
Sponsored By:
Soundstream Audio
NRG Innovations
Air lift Company
Old 03-18-2009, 08:37 PM   #13
sharkattach
sharkattach 113/M
are you f*#King for real......the motor will not blow if you go to 5k....your a f*&king retard. the reason is for more powers...what the hell do you have a s/c if you only shift before it ever makes real power.
Old 03-18-2009, 08:39 PM   #14
aen
dope dope dope
aen 25/M
actually, the way our cam lobes are done we lose tq but gain hp after 5200 rpms.
bassically that's right where you want to shift if you want a constant powerband.
Old 03-18-2009, 08:43 PM   #15
b52hDUNN
b52hDUNN's Avatar
b52hDUNN 27/M
Just cause you have a s/c that doesnt mean that you bounce the car off of the rev limiter. lol. And yes you can over rev the motor and threw some valves into the piston. I make power at 2k rpm, it is a supercharger by the way! Dang dude your the retard. 30miles in 3+ gallons.... you seriously f-ed something up.
Old 03-18-2009, 09:27 PM   #16
athlete3232
athlete3232's Avatar
athlete3232 21/M
if you want help, dont bash on the ppl trying 2 help you.. lol
athlete3232 is offline   Reply With Quote
Old 03-18-2009, 09:30 PM   #17
mcheng08
mcheng08 27/M
Send a message via AIM to mcheng08
Quote:
no advice here, just agreeing ^^^
*2007 Flint Mica Tc*
mcheng08 is offline   Reply With Quote
Old 03-19-2009, 01:57 AM   #18
HEYitzMEEE
HEYitzMEEE's Avatar
HEYitzMEEE 23/M
Send a message via AIM to HEYitzMEEE
My suggestion like above stated, make sure the injectors are seated properly. I had this problem and my motor wouldn't go past 4600 and then my car cut off.
And to Dunn, where does he even talk about "bouncing" off of the limiter? If i'm reading correctly, he says he can't shift past 5k. And just because someone shifts past 5k, doesn't mean they bounce. There are some people out there that aren't bad drivers ;)
* BLOWN MOTOR *
New project, HELLO 07 Civic SI COUPE!
For sale? Why yes I am!
Scion tC Parts:
http://www.scionlife.com/forums/view...522&highlight=
Nissan 350z Parts:
http://www.scionlife.com/forums/view...904&highlight=
HEYitzMEEE is offline   Reply With Quote
Old 03-19-2009, 02:38 PM   #19
b52hDUNN
b52hDUNN's Avatar
b52hDUNN 27/M
Default Re: tc not running right after installing s/c
Quote:
Right there!
Old 03-19-2009, 04:46 PM   #20
sharkattach
sharkattach 113/M
you know how if you hit the rev limiter(if you keep you foot on it) and it will stay there and bounce off of it.....well at 5500 the motor just dies, the rpm will drop until you lift your foot and hit the gas again. but it will not go past 5500
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
5500, installing, nonrunning, reving, running, sale, sc, scion, tc, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
