screeching noise some help please
Old Mar 27, 2009 | 05:28 AM
skatearizona's Avatar
Default screeching noise some help please
ok i have searched for a fourm on this subject and couldnt find what i was lookin for.
I have a bad screeching noise coming from the belt area of my car when it is cold outside or when my ac is on and when my rpms hit 4000 on a blitz super charged engine. does anyone know the problem and how to fix it? your help will be greatly apreciated thanks
Old Mar 27, 2009 | 08:10 AM
jcs_xb's Avatar
it could be your alternator belt....
i used to have a problem like that with my OLD rav-4 ( 98 )
everytime i turned the ac on a high pitch screeching sound happens...
so i checked my belts and my alternator was all crap...
it was old and needed a change...
so then i changed it (cost me less than 100 bucks, not sure on the xb)
and it solved my probelm....
hope this helps man...Good Luck
Old Mar 27, 2009 | 08:14 AM
ProjectGreen's Avatar
Wait, are you supercharged? If so what pulley are you running.
I had this same problem in my tC, where the mechanism that adjusts the tension on the belt cant handle smaller pullys and it squeals for some reason.
IDK Just my suggestions.
Old Mar 27, 2009 | 08:18 AM
Tomas's Avatar
Admin Emeritus
No real tensioner on the xB Classic, but if the belt is not tightened to spec it WILL squeal under load, ESPECIALLY when cold.
Pretty common - Adjust belt tension before you damage the belt.
(Or replace belt of it is old enough to be questionable.)
Old Mar 27, 2009 | 01:40 PM
swartzautoman's Avatar
tomas nails it agian.
thats my vote, eather your belt is bad or loose
kb1sxv
Oct 21, 2015 05:00 PM
Klashan
Sep 24, 2015 12:39 PM
Andreas24
Sep 15, 2015 02:10 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
alexbarspin
Sep 3, 2015 02:04 AM
