turbo timer help!!!!!!!!!!!!!!!!!!
Old Apr 2, 2009 | 02:48 PM
Troys_tc's Avatar
Default turbo timer help!!!!!!!!!!!!!!!!!!
ok I put a pivot flat full auto turbo timer in my tc, used the ptuning pnp harness and everything works great on the timer, but I am having an issue withthe factory alarm unlocking after the turbo timer finishes its cycle. Does anyone have a fix for this? because I am sure that I am not the first person to run into this problem, and this is irritating me, because I have to stay in or around my car until the cycle is done running.
anything will help at this point
Troy
Old Apr 2, 2009 | 10:54 PM
ValenciaS's Avatar
I have the Greddy turbo timer and i cant lock my doors with my key while its running , I just lock my doors manually from the inside before i get out. Just a thought.
Old Apr 3, 2009 | 01:23 AM
Troys_tc's Avatar
See, my car unlocks, when the timer is done runing and the car finally shuts off, its like auto unlock
Old Apr 3, 2009 | 02:54 AM
jsg93085's Avatar
Do you have just the keyless entry or do you have the Scion Security?
Old Apr 3, 2009 | 10:51 AM
Troys_tc's Avatar
I don"t know, i bought the car used and it came with a jacked up remte that i have broke scince
Old Apr 6, 2009 | 07:08 PM
ValenciaS's Avatar
maybe a wire is connected wrong ?
Old Apr 6, 2009 | 07:12 PM
jsg93085's Avatar
doubtful, it seems that his alarm on the car unlocks the doors when the engine is turned off (as most alarms will do)
i have the zenesis e502 alarm, it has a built in turbo timer (max of 2 mins, but it is still good to have) and it stays locked once i lock it after getting out of my car
Old May 17, 2009 | 04:12 PM
jamie1tc's Avatar
Troy.....did u come up with a solution for ur doors unlocking?
jamie1tc's Avatar
Old May 17, 2009 | 04:50 PM
Troys_tc's Avatar
No, but I was told I need to remove my alarm and put in a differnt one, which I haven't had time to look into
SloTC1
Aug 16, 2018 02:45 PM
greytc
Oct 26, 2015 07:53 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
SJMiller
Sep 12, 2015 06:33 PM
