Go Back   Scionlife.com » Scion tC First Gen » Scion tC 1G Owners Lounge » Scion tC 1G ICE & Interior
Register Forgot Password?
Reply
Old 04-02-2009, 03:17 PM   #1
rcf22
rcf22's Avatar
rcf22 25/M
Default Crackling in Speakers
Strange issue I'm having with my audio system the last couple weeks... When I have my wheel cranked to the left, I hear an occasional crackling sound through my speakers. It seems to happen most often when I'm accelerating through a turn, but that might just be because I'm always cornering hard :p
At any rate, it only happens when the wheel is cranked left, and not right. Any reason this could be? Should I just try another grounding location? Right now my amp is grounded to the baby seat thingie bolt in the hatch. I'm sure someone will tell me it's the ground, but it seems strange to me that the noise is only heard when the wheel is turned one direction.
rcf22 is offline   Reply With Quote
Old 04-02-2009, 03:37 PM   #2
BZinn1
BZinn1's Avatar
BZinn1 43/M
loose speaker wire,did you solder the wires to the speaker terminals,if not it probably is shorting as you go in tothe corner.......and slow down.......we don't want to have another I just killed my tC thread.
Build it like you dream it.....
BZinn1 is offline   Reply With Quote
Old 04-02-2009, 04:44 PM   #3
rcf22
rcf22's Avatar
rcf22 25/M
The connections are solderless. I had heard that soldering speaker connections could bad idea since the solder can introduce noise to the system, dunno if there is any truth to that or not. I can go back and check the connections to the crossovers and then to the speakers though, that sounds like it could be a possibility. Thanks for the idea.
Flickr | Canon EOS 500D | 18-55mm IS | 50mm f1.8 | 55-250mm IS
Old 04-02-2009, 06:34 PM   #4
kiss_kiss_kill
kiss_kiss_kill's Avatar
kiss_kiss_kill 26/F
Send a message via MSN to kiss_kiss_kill Send a message via Yahoo to kiss_kiss_kill
Y'know, it's weird. My supercharger interferes with my speakers.
PROUDLY BOOSTED BY: Descendant-Racing
PROUDLY SPONSORED BY: Toyo Tires, Memphis Car Audio, Killerglass, Xenon-Vision, & AutoFashion USA
PROUD MEMBER OF:
AUTO CONCEPT ELITE
SEMA 2007 Feature Car for Air Runner
SEMA 2008 Booth Car for Killerglass
SEMA 2009 Feature Car for SEIBON
kiss_kiss_kill is offline   Reply With Quote
Old 04-02-2009, 07:22 PM   #5
BZinn1
BZinn1's Avatar
BZinn1 43/M
get louder speakers.........lol........sorry you know I had too.
Old 04-02-2009, 07:34 PM   #6
kiss_kiss_kill
kiss_kiss_kill 26/F
Well, the issue no longer exists. The supercharger's sitting in a box in my garage, waiting for someone to come buy it, lol.
PROUD MEMBER OF:
AUTO CONCEPT ELITE
Old 04-02-2009, 09:55 PM   #7
nodsetse
nodsetse's Avatar
nodsetse 52/M
Quote:
A good solder connection won't induce noise into the system. The downside to soldering (besides more time & effort) is the potential to damage the speaker, due to overheating the voice coil. The possibility of it happening depends on the type of speaker, but you should always use a heatsink (like a set of hemostats in this case) clamped to the leads between the terminal and vc, to absorb a lot of the heat so it doesn't overheat the vc.
Nothing wrong with solderless connections when done right, but it sounds like one of yours may be marginal.
'06 Azure Pearl tC 5spd
nodsetse is offline   Reply With Quote
Old 04-02-2009, 10:36 PM   #8
Mouse
Moderator
Moderator
Mouse's Avatar
Mouse 40/M
Well there could've been a few different reasons for that with the s/c on....but why did you decide to take it off? Didn't you spend a lot of time polishing the housing to a mirrored shine?
Got Cheese? :D
"Always remember in life... It's NOT how many times you get knocked down that's important...it's how many times you get back up."
Current - 2008 SCM tC -- Previous - 2006 CSM tC
DANTEGTS <---- Sponsorship. Great seller & quality products. SL member.
Murphys_Law
<---- Great SL seller.
"SEARCH" Is your friend
Mouse is offline   Reply With Quote
Old 04-06-2009, 12:50 PM   #9
daxII
daxII 38/M
Sounds like something is definitely loose somewhere. I would check all of your power and ground connections, especially if you're using distribution blocks. Check all the amp terminals as well as your RCAs on the head unit. Also, as long as you're not cold soldering your connections, soldering your speaker wire to mids and tweeters is pretty much the way to go. I've never had a problem going this route, either with sound degradation or intermittent output. Hope you're able to find the source of your problem.
Alpine CDA-9887
Phoenix Gold Tantrum 1200.1
Phoenix Gold Tantrum 600.4
Phoenix Gold Bass Cube
Phoenix Gold TLD-66 Line Driver
1 Fi Audio Q 12" Sealed
Phoenix Gold Rsd65 Components (Active)
daxII is offline   Reply With Quote
Scionlife.com
Scion TC
Paid Advertisement
Reply
Tags
crackle, crackling, scion, soldering, speaker, speakers, tc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
