yep!
and that answer IS.... about 4-5 inches.
the only time I rubbed was on really big dips in the road at hwy speeds in teh back and if I was turning and hit a dip up front.
was running 15x8 zero offset with a 195/45 tire.
I am closer to 5 inches from stock.
and here is that same drop with steelies,
and with the xA alloys with a 195/60 tire(have no idea why that size) but it does dub pretty bad front and back.
But I don't know of any springs that will drop you that much, you will have to go with coil overs, and if you do that you can fine tune the height to the point where it does not rub, and you are happy with it.
Founder DC (Driveway Customs)
Quote:
Originally Posted by MarkLim
Wow! I just love the theme. Looks like you bought it from satan himself at his scion dealership in hell.
The 15 inch rim size is irrelevent by the way. You can go 3-5 inchs lower without rubbing depending on tire size wheel width and offset. A 15 inch rim with stock tires has essentially the same clearance as an 18 inch rim with similar offset and width using 205/35/18 tires. In other woirds there would be very little difference in clearance between stock 15's, stock 17's, and stock 18's.
You wanna really go low?? BAG IT Then you can go almost to the ground when stopped and ride at whatever height suits you depending on the terrain you are driving on
Badly afflicted with Corvair disease and now Scionitis Good thing the only treatment is playing with Corvairs and Scions
well the offset that i want to go for is 10et.will there still be a problem with that?
i just dont want to rub as much as i did when had a 0 offset. horrible.
i already have rolled fenders.
well the plan for the tires that i want to roll would be 195/50/15.
and i am on s-tech's.would the wheel gap noticeable if i go 195/50?
i just want it to look clean and nice.and still be able to stuff 3 or more people
in the car like i used.and be able to drive good with no rubbing issues at all.
yep!
I am almost as low on coils
"You are not Sancho" 2010 MB ML350 Bluetec 2013 Ford Explorer Sport... Tune coming
2013 Wrangler Unlimited Sahara
Twitter:@sciond/facebook:sciond
There is no new Scion I can buy that fits my needs....
yep here is 18's slammed
