Knock sensor
Old Jan 16, 2005 | 08:04 PM
Dansthunder's Avatar
DeepSouth Scions
Default Knock sensor
Does anyone know if the xb has one?
Old Jan 16, 2005 | 08:12 PM
mikochu's Avatar
Yup, it's behind the intake manifold...
Old Jan 16, 2005 | 09:26 PM
DeepSouth Scions
Does it use a crank or cam sensor?
Old Jan 17, 2005 | 04:34 AM
is there a check engine light on?
Old Jan 17, 2005 | 11:44 AM
DeepSouth Scions
No, I just wanted to know. There is nothing wrong with my car.
Old Jan 19, 2005 | 02:22 AM
Davestoaster's Avatar
Yup, he's right. It's a big job to get to. It's right above the oil pressure sender. The knock sensor doesn't use either the cam or the crank. It senses the preignition in the cylinders and retards or advances the timing through the ECM.
Old Jan 19, 2005 | 02:32 AM
mikochu's Avatar
In the service manual, it tells you to take out the airbox and intake manifold to get to it...
Old Jul 26, 2025 | 12:54 AM
Bondy's Avatar
Default Knock sensor connection
I have a 09 Scion Tc. Throwing a code for high voltage at knock sensor intermittently. It was suggested to check the connector first. However, if it's going to be a pain in the **** to get to, I might as well replace the knock sensor. I haven't found anything that tells me if I can even see the knock sensor without removing the manifold, etc. Any advice, suggwould be greatly appreciated
kb1sxv
Oct 21, 2015 05:00 PM
MeDizzy
Oct 8, 2015 03:31 PM
prescottn
Sep 22, 2015 01:30 PM
gqdabien
Sep 17, 2015 09:23 PM
Topfueltom69
Sep 6, 2015 05:25 PM
